DRIVE OS Version: 7.0.3
Issue Description:
I’d like to get DriveOS core deb packages for our DRIVE Thor development.
Thanks to the developer guide, I have obtained cuda-libraries and cuda-toolkit deb packages from the NGC registry.
Unfortunately, I cannot install the nvsci packages because no nvsci_*.deb is found neither in the my host machine or in the NGC registry.
How can we obtain the nvsci deb packages for DRIVE Thor?
Thanks,
Dear @matsumiya.r ,
May I know the objective? The nvsci libs are part of DRIVE OS already.
nvidia@tegra-ubuntu:~$ ls /usr/lib/libnvsci*.so
/usr/lib/libnvscibuf.so /usr/lib/libnvscic2cpcie.so /usr/lib/libnvscievent.so /usr/lib/libnvscisync.so
/usr/lib/libnvscic2c.so /usr/lib/libnvscicommon.so /usr/lib/libnvsciipc.so
/usr/lib/libnvscic2ccommon.so /usr/lib/libnvscicommon_debug.so /usr/lib/libnvscistream.so
Thank you for response,
I know the nvsci libs are included in the DRIVE OS.
However, I want some deb packages including such objects for cross-compilation in my x86_64 host machine outside docker.
Is there no other way but to copy directly such libs (and headers) from the DRIVE OS or the SDK container?
The requirement is to cross compile on your host machine instead of docker environment? Seperate x86 nvsci debians are not avaialable
Yes, my wish is to cross compile on my host machine instead of docker.
We will consider some workarounds then.
Thank you for your answer.
