I want to setup a development platform with the new Jetson Orion NX, which carrier board should I use?
You should file the topic in correct forum first.
Yes. I just moved the topic to Jetson Orin NX.
Are you asking about custom board from vendor or NV devkit option?
Yes, I prefer to using a NV devkit board, though a customer board from third party/NV partner is also acceptable. Thanks.
In addition, I see the Orin Nano has a devkit from NV. Does Orin NX has such a devkit from NV as well? Or should I buy the Orin NX module and a carrier board to put hem together as a devkit? Thanks.
Yes, you can put the orin nano devkit carrier board with orin nx module.
You can also use orin nx module with xavier nx devkit.
