Which dts file to use, to enable max96712
Hi Sir,
I am using r36.4.3, based on p3737+p3701.
I would like to enable our camera using a multi-channel GMSL board.
However, there are so many dts files addressing max96712 under the folder:
~/linux_src/hardware/nvidia/t23x/nv-public/overlay
tegra234-camera-p3783-a00.dtsi
tegra234-p3737-camera-dual-hawk-ar0234-e3653-overlay.dts:
tegra234-p3737-camera-modules.dtsi:
tegra234-p3737-camera-p3762-a00-2Hawk-overlay.dts:
tegra234-p3737-camera-p3762-a00-3Hawk-3Owl-overlay.dts:
tegra234-p3737-camera-p3762-a00-4Hawk-overlay.dts:
tegra234-p3737-camera-p3762-a00-4Owl-overlay.dts:
tegra234-p3737-camera-p3762-a00.dtsi:
tegra234-p3737-camera-p3762-a00-overlay.dts:
Could you tell me which dts file is the right one that I can get started with ?
Many thanks.
Jimmy
Suppose you need to check each of them and compare with your design.
@ShaneCCC
Thanks for the reply.
Our GMSL boards support 4 Quad deserializers(max96742, mx9296), connecting 10 STURDeCAM31 cameras, using 3MP Sony® ISX031
And this GMSL camera claims that it is for Jetson Agx Orin platform.
And I search the folder again, as below:
It seems that the dtb description depends on image sensor choice closely.
Could you provide more information & hint ?
Many thanks.
Jimmy
Maybe checking the programing guide first.
