Hi, I have encountered a problem with my Jetson Nano: it shuts down when current (load) changes quickly. I suspect that it must be due to the power supply, or more specifically inductance in the wires which causes undervoltage.
Please could you tell me if Jetson Nano is expected to shut down because of the built-in (automatic) undervoltage protection?
Firstly, you need to unplug all connections to Jetson Nano (may include HDMI, LAN, USB…)
Secondly, if the first not working, you should check the voltage of your power supply, Jetson nano won’t working with Voltage <4.85V.
If it still not working, check Ampe numeral on your power, if it smaller than recommended, you should choose other
