Monocular Camera Calibration
This tutorial uses a 6x8 checkerboard with 200mm squares.
Does this mean that the side length of each small square on the checkerboard is 200mm? Is it too big? Or should it be 20mm?
Like the picture you printed, the checkboard must have:
On the Camera Calibration Pattern Generator – calib.io you can set these parameters:
After that check if every tile measure 20 x 20 mm square
If there are any issues, let me know.
Best,
Raffaello
