Hi nvidia:
I just want to control gpio-289 on platform/2200000.gpio, tegra-gpio,i have seem that:
root@ubuntu:/sys/class/gpio# cat /sys/kernel/debug/gpio |grep gpio-289
gpio-289 ( |vdd-12v-pcie ) out hi
but when i export this pin as following:
root@ubuntu:/sys/class/gpio# ls
export gpiochip240 gpiochip248 gpiochip288 unexport
root@ubuntu:/sys/class/gpio# echo 289 > export
bash: echo: write error: Device or resource busy
it seem that it is register as a GPIO from above output,but why i can’t export gpio-289 and change it?
I have check https://developer.nvidia.com/embedded/downloads#?search=Jetson%20AGX%20Xavier%20Series%20Pinmux and learn that it is initial as a GPIO as following:
GPIO05 A59 DAP6_DOUT GPIO3_PA.01 I2S6_SDATA_OUT RSVD2 NORMAL NORMAL DISABLE 0 GPIO3_PA.01 Output Drive 0 N/A GPIO_VDD_12V_ENABLE on CVB
must i modify it in device tree?
thanks!
