Hi All,
I install this version,
Package: nvidia-jetpack
Version: 4.6.4-b39
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
I notice this version did not have JupyterLab.
So, I follow this step. How to Install Jupyter Lab on JP4.4
My wifi wlan0 is <192.168.xxx.xxx>. So, i try 192.168.xxx.xxx:8888. But cannot open jupyterlab.
I use
jupyter notebook --no-browser
I only can access using localhost <127.0.0.1:8888>.
May I know, why I cannot open or install jupyterlab is wrong step?
Could you try if manually importing the IP can work?
jupyter notebook --ip xx.xx.xx.xx --port 8888
Thank you for the solution. I can open jupyter by using own IP address. Follow this website How to Install Jupyter Lab on JP4.4
I believe, i work on virtual environment deepstream.
Now, I continue follow this step, Step5 https://www.waveshare.com/wiki/JetRacer_AI_Kit#2._Software_setup
Step 5. Install the python package
- Access JetRacer by going to http://<jetracer_ip_address>:8888
- Launch a new terminal. The default user name and password are both jetson.
- Switch the Jetracer batch to the Master.
cd Jetracer
sudo git checkout master
sudo python3 setup.py install
sudo reboot
I cannot continue step 5. Can you help me?
