How do I make a certain set of windows always up when I start Create? So I dont have to check them in the list under window or load a layout everytime?
And also, it is not possible to add Movie capture-window in to the saved layout. I always have to turn it on manually and move to where I want it. It would be great if that could also be saved in the Layout.
Hello @Jack_Jensen! Check out our documentation here: User defined layouts Let me know if this helps answer your question or if you have any more questions!
This User defined layouts is able to save my defined layout, but it doesn’t auto load. I have to manually load it every time when I open the app. Is there a way to autoload a user defined layout on app start?
