We are working on the AGX Xavier platform.
When we light up the camera sensor, we find that the original data has a reverse color difference.
The raw data of our camera is yuyv422.Our code modify as below:
dtsi:
When I use command “v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=YUYV --stream-mmap --stream-count=1 -d /dev/video4 --stream-to=ov5693.raw” get the raw data…
Open the raw data file with YUYV is abnormal,but UYVY is ok.
YUYV:
The setting is correct to set as YUYV, not sure what happened for it.
Could you try to configure the sensor output UYVY and VI configure as YUYV for experiment.
I use the command of “v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=YUYV --stream-mmap --stream-count=1 -d /dev/video4 --stream-to=ov5693.raw” to get the image data.
1 ) Does it get the raw data ?
2) Does this command( v4l2-ctl ) do data format conversion or not ?
OK, Let make the problem clear.
Do you set the YUYV by the v4l2-ctl command line but didn’t modify the sensor REG to output YUYV data format? If yes that could be the problem. You need to configure the sensor REG to output pixel format match the dt setting instead of use the command to configure it.
First, Our image sensor supplier said that the default output of the original data format is yuyv. Secondly, I modified the data image format to yuyv in dtsi file to match the image sensor consistency.Then,I use the above command to get a frame of image data. So I use yuv tool to preview the photo.:
When I set the data format of yuyv to preview the image data, it does not display properly
When I set the data format of uyvy to preview the image data, it displays normally
But the original image data is yuyv, and I have set it to yuyv. I don’t know why it doesn’t work ?
I asked the supplier to change the sensor register to uyvy. No matter whether my device tree is changed to uyvy or yuyv, it will display normally.,I have a little confused.
I used 7yuv to check the raw data.
Attached is the image data captured with the command of v4l2-ctl
The imager sensor output YUYV and I set to YUYV,But it can not display normal.
