hi,i use sdkmanager1.5 install xavier.when it installed,i try to run darknet demo for test,it show the error:CUDA Error:CUDA driver version is insuffiient for CUDA runtime version.
i found the sdkmanager install the CUDA version is 10.2,and the cudnn version is 8.0
so does anybody met the same thing? BTW,i used sdkmanger1.3 and the CUDA version is 10.0 ,it run OK in XAVIER.
Do you recompile the darknet for new JetPack environment?
If not, would you mind to give it a try?
yes,i clone from github and already make.
i got the answer.when i used the flash jetson os,the error never found.
