I copy the cuda-10.0 and cudnn 7.5.0 from jetpack 4.2.1 to jetpack 3.1 installed tx2 without any other installation. I compiled project successfully. But when i tried to run
The code I am running.
https://github.com/AlexeyAB/darknet
CUDA status Error: file: ./src/dark_cuda.c : () : line: 36 : build time: Aug 6 2019 - 14:04:29
CUDA Error: CUDA driver version is insufficient for CUDA runtime version
CUDA Error: CUDA driver version is insufficient for CUDA runtime version: Success
darknet: ./src/utils.c:293: error: Assertion `0' failed.
As i understand from the error , gpu driver is not sufficient ? But is it possible to update it ?
Are there any things i can do beside moving on 4.2.1. I know it works correctly.
