Hi all,
I’ve been trying to install CUDA 9.0 and CUDNN 7 on a Jetson TX2 with the JetPack version 3.3.
All the installation goes well, but when I copy the sample and compile deviceQuery and try to run it I guess an error. At the moment, I didn’t try to flash the Jetson just yet because I need it in a certain configuration right now. But in the next couple of weeks I’ll flash it but I’m afraid that I’ll still get the same issue. Anyway here’s the error :
“CUDA driver version is insufficient for CUDA runtime version”.
I assume that the problem is cause because of the version CUDA toolkit and the CUDA driver, but like I said I’ve installed it with the JetPack which is the most recommended option I’ve found regarding installing CUDA on the Jetson.
So my question is, how can I fix this error if it comes from the JetPack installation and that there’s no really other way to install CUDA on the Jetson TX2 ?
Also maybe some other information will help :
Copyright (c) 2005-2017 NVIDIA Corporation
Built on Sun_Nov_19_03:16:56_CST_2017
Cuda compilation tools, release 9.0, V9.0.252
Running Ubuntu 16.04
Kernel 4.4.38
Anything will help and thank you in advance.
Cheers,
Ludovic
