Hello. I am unable to flash my Xavier NX dev kit (for the fist time). Try as I might I cannot get it to show up as a USB device. I am placing a jumper on pins 9&10, prior to power-on, which I believe should cause the device to boot in to recovery mode. However, I don’t see any sign of a USB device. Is there any other troubleshooting I can do before RMA?
Hi @dusty_nv. Yes, the green LED comes on, but no other sign of life → no fan & nothing on the hdmi output. I have tried with the SD card instructions, as well as with the SDK/jumper.
Hmm ok. So when you connect it’s Micro-USB port to your Linux PC, boot it into recovery mode, and run lsusb from your PC - you don’t see any NVIDIA device there?
are you referring to the pins 9&10 on the top of the board or on the side of the board [covered on the top by NX module]. If the former is the case and you are approaching pins 9&10 which are located at GPIO at the top side of the board - they are not the pins to be used.
