We are looking to design a custom mechanical case with thermal implementation for the NX. The file available at [https://developer.nvidia.com/embedded/jetson-xavier-nx-3d-cad-step-model] has this file [Jetson_Xavier_NX_Module_3D_STEP_Model_nv.zip]
The level of detail in this external envelope CAD is not as good as the one available for the Jetson Nano module 3D CAD.
Would it be possible to get the detailed model?
Would be great if it can capture details as in the image above. Thermal and mechanical design requires accurate knowledge of the vertical projections both for top & bottom faces of the module.
Thank you in advance!
