on my board we designed, we use usb2.0.1 and usb 2.0.2 for host and usb type A port, we change device tree. but still have problems.
the log as follow:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-1935) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Dec 9 22:52:02 PST 2019
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44600000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
<hit enter to activate fiq debugger>
[ 1.936784] tegra-slvs-ec 15ac0000.slvs-ec: probe failed: -19
[ 2.046088] Reading powergate-id failed
[ 2.046271] tegra-xusb 3610000.xhci: failed to get SS powergate id
[ 2.329157] tegra210-axbar tegra210-axbar: Can't retrieve parent clock
[ 27.780108] cgroup: cgroup2: unknown option "nsdelegate"
[ 27.781648] pstore: decompression failed;returned -5
[ 29.091012] random: crng init done
[ 29.091110] random: 7 urandom warning(s) missed due to ratelimiting
[ 29.815203] CPU4: shutdown
[ 29.887472] CPU5: shutdown
[ 29.948214] CPU6: shutdown
[ 30.011516] CPU7: shutdown
I have changed the device tree according to the adaptation. Because there is no usb device so I remove the USB PD controler part and xudc part.
xusb_padctl@3520000 {
compatible = "nvidia,tegra19x-xusb-padctl";
reg = <0x0 0x3520000 0x0 0x1000 0x0 0x3540000 0x0 0x1000>;
reg-names = "padctl", "ao";
interrupts = <0x0 0xa7 0x4>;
resets = <0x5 0x72>;
reset-names = "padctl";
status = "okay";
pex_dvdd-supply = <0x7e>;
pex_hvdd-supply = <0x7f>;
pex_pll_hvdd-supply = <0x7f>;
vclamp_usb-supply = <0xa>;
avdd_usb-supply = <0xe2>;
avdd_pll_nvhs_eutmip-supply = <0x7f>;
linux,phandle = <0xe4>;
phandle = <0xe4>;
pads {
usb2 {
clocks = <0x4 0xa5>;
clock-names = "trk";
lanes {
usb2-0 {
status = "okay";
#phy-cells = <0x0>;
nvidia,function = "xusb";
linux,phandle = <0xe5>;
phandle = <0xe5>;
usb2-1 {
status = "okay";
#phy-cells = <0x0>;
linux,phandle = <0xe7>;
phandle = <0xe7>;
usb2-2 {
status = "okay";
#phy-cells = <0x0>;
linux,phandle = <0xe9>;
phandle = <0xe9>;
usb2-3 {
status = "disabled";
#phy-cells = <0x0>;
linux,phandle = <0xe8>;
phandle = <0xe8>;
usb3 {
lanes {
usb3-0 {
status = "okay";
#phy-cells = <0x0>;
linux,phandle = <0xea>;
phandle = <0xea>;
usb3-1 {
#phy-cells = <0x0>;
usb3-2 {
#phy-cells = <0x0>;
linux,phandle = <0xe6>;
phandle = <0xe6>;
usb3-3 {
#phy-cells = <0x0>;
linux,phandle = <0xeb>;
phandle = <0xeb>;
ports {
usb2-0 {
status = "okay";
vbus-supply = <0x1c>;
mode = "otg";
usb2-1 {
status = "okay";
mode = "host";
usb2-2 {
status = "okay";
mode = "host";
usb2-3 {
vbus-supply = <0xe3>;
mode = "host";
usb3-0 {
status = "okay";
nvidia,usb2-companion = <0x1>;
usb3-1 {
usb3-2 {
nvidia,usb2-companion = <0x0>;
usb3-3 {
nvidia,usb2-companion = <0x3>;
nvidia,usb3-gen1-only = <0x1>;
prod-settings {
#prod-cells = <0x4>;
prod_c_bias {
prod = <0x0 0x284 0x38 0x38>;
prod {
prod = <0x0 0x24 0xfff 0x0>;
usb_cd {
compatible = "nvidia,tegra194-usb-cd";
nvidia,xusb-padctl = <0xe4>;
phys = <0xe5>;
phy-names = "otg-phy";
status = "okay";
linux,phandle = <0x1d1>;
phandle = <0x1d1>;
xhci@3610000 {
compatible = "nvidia,tegra194-xhci";
reg = <0x0 0x3610000 0x0 0x40000 0x0 0x3600000 0x0 0x10000>;
interrupts = <0x0 0xa3 0x4 0x0 0xa4 0x4 0x0 0xa7 0x4>;
interrupt-parent = <0x39>;
clocks = <0x4 0x10a 0x4 0x10b 0x4 0x10c 0x4 0x10d 0x4 0x10e 0x4 0x10f 0x4 0x110 0x4 0x111 0x4 0x113 0x4 0x115 0x4 0x67 0x4 0xe 0x4 0x64>;
clock-names = "xusb_hs_src", "xusb_host", "xusb_core_superspeed_clk", "xusb_falcon_src", "xusb_falcon_host_clk", "xusb_falcon_superspeed_clk", "xusb_fs_src", "xusb_fs_host_clk", "xusb_ss_src", "xusb_ss", "pll_u_480m", "clk_m", "pll_e";
iommus = <0x2 0x1b>;
dma-coherent;
status = "okay";
extcon-cables = <0x81 0x1>;
extcon-cable-names = "id";
#extcon-cells = <0x1>;
phys = <0xe5 0xe7 0xe9 0xea>;
phy-names = "usb2-0", "usb2-1", "usb2-2", "usb3-0";
linux,phandle = <0x1d3>;
phandle = <0x1d3>;
I plug the usb mouse into the usb type A port, the led on mouse don’t flash. and no any information in kernel. no any information when use the command “lsusb”.
