Xavier watchdog example
Do you have any example showing how to setup and use the watchdog on Xavier?
Have a check below link.
Hi @ShaneCCC,
I need to set the Watchdog in CBoot before the system starts in order to grant a safe boot and in case switch to A/B rootfs.
Do you have any code sample for Watchdog in CBoot or any detail about that?
@MarukoBG
Watchdog already enable in cboot in default.
@ShaneCCC,
could you be more explicit please?
How to you start it in CBoot?
Have a check the source code in …/bootloader/partner/common/drivers/wdt/tegrabl_wdt.c
