ZED x mini on isaac ros - argus problems
Hey,
Lately I’ve been trying to run the latest version of isaac ros for JP6 with zedx mini.
I connect my zed camera via Stereolabs dual connector (GMSL) and also have it’s newest driver installed.
Trying to run isaac-ros-argus-camera, it crashed on the gxf rectification step. I then commented out the step:
  - type: nvidia::gxf::Connection
    parameters:
      source: argus_camera/left_camera_output
      target: converter_left/data_receiver
    parameters:
      source: converter_left/data_transmitter
      #     target: rectify_parameters/left_receiver
      # - type: nvidia::gxf::Connection
      #   parameters:
      #     source: rectify_parameters/left_transmitter
      target: stereo_camera_synchronizer/rx_left_camera
and saw that I indeed get the data via /left/image_raw topic (of course the /left/camera_info isn’t published since it needs the rectification step).
I then investigated more and found out that the problem in the rectification step is that the previous step: nvidia::isaac::ArgusCamera is indeed sending the stream of the stereo camera but not the calibration data (all zeros).
Then I have installed Jetson Multimedia Api and ran “argus_syncstereo” and saw that it does identify the cameras correctly and the gets frames from both camera but the calibration data is all zeros:
Executing Argus Sample: argus_syncstereo
Argus Version: 0.99.3.3 (multi-process)
getSensorPlacement for sensor 0 is DEFAULT_SensorPlacement
Found : ZED_CAM1
getSensorPlacement for sensor 1 is SENSOR_PLACEMENT_REAR_OR_BOTTOM
Found : ZED_CAM1
getSensorPlacement for sensor 2 is SENSOR_PLACEMENT_REAR_OR_BOTTOM
Found : ZED_CAM2
getSensorPlacement for sensor 3 is SENSOR_PLACEMENT_REAR_OR_BOTTOM
Found : ZED_CAM2
Total Module Count is 2
Identified stereo camera module ZED_CAM1 with the following 2 sensors connected:
0
1
Identified stereo camera module ZED_CAM2 with the following 2 sensors connected:
2
3
Session[0] : add camera device 0
Session[0] : add camera device 1
PRODUCER: Creating stream[0].
PRODUCER: Creating stream[1].
Calibration data of sensor 0 (device 0) of session 0:
 Image size = 0, 0
 Focal Length = 0.000000, 0.000000
 Principal Point = 0.000000, 0.000000
 Skew = 0.000000
 Fish Eye mapping type = MAPPING_TYPE_EQUIDISTANT
 Lens Distortion type = DISTORTION_TYPE_POLYNOMIAL
 Radial coeffs count = 0
 Radial coefficients =
 Tangential coeffs count = 0
 Tangential coefficients =
 rot3d x, y, x{0.000000, 0.000000, 0.000000}
 translation 3d x, y, x{0.000000, 0.000000, 0.000000}
I suspect that this what cause the rectification step to crash on the gxf, but maybe I got it wrong.
Is this a known problem? what should I do to fix it? is there a workaround for this? this cause the whole isaac ros problem not to work and prevents me to continue.
I have also posted on zed stereolabs forums a question about it (maybe driver) and the directed me here.
Thank you.
Hi @shimoni
Thank you for your detailed post and for working with Isaac ROS.
At this time, ZED support for Isaac ROS 3.0 is temporarily disabled and will be available soon.
I keep you updated on other news.
Thank you in advance,
Raffaello
Hey, thanks!
Is there any ETA for this feature?
Adi.
Hi @shimoni
Unfortunately, I cannot confirm an ETA, but it will be included in a future release.
Raffaello
