I’m running driver version 337.25 on an Archlinux 64 bit system. This problem occurs both on the CK kernel and standard kernel. I can run the 1440p monitor or 1080p monitor alone, when I attempt to run both, only the 1440p monitor works. The 1080p is attempting to run at 2048x1536. When I attempt to run it at a lower resolution, which is scaled, it still fails to run. Here is my /etc/X11/xorg.conf
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 331.20 (buildmeister@swio-display-x86-rhel47-05) Wed Oct 30 18:20:32 PDT 2013
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 331.20 (buildmeister@swio-display-x86-rhel47-05) Wed Oct 30 18:20:53 PDT 2013
#Section "Device"
# Identifier "Device1"
# Driver "nvidia"
# VendorName "NVIDIA Corporation"
# Screen 1
#EndSection
Section "ServerLayout"
# Removed Option "Xinerama" "1"
# Removed Option "Xinerama" "0"
Identifier "DualScreen"
Screen 0 "Screen0" 0 0
Screen 1 "Screen1" 2560 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "StandbyTime" "30"
Option "SuspendTime" "60"
Option "OffTime" "90"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "DFP-3"
DisplaySize 597 336
HorizSync 88.8 - 160.0
VertRefresh 59.5 - 120.0
ModeLine "2560x1440" 241.50 2560 2608 2640 2720 1440 1443 1448 1871 +hsync -vsync
ModeLine "2560x1440_60" 312.25 2560 2752 3024 3488 1440 1443 1448 1493 -hsync +vsync
ModeLine "2560x1440_75" 397.25 2560 2760 3040 3520 1440 1443 1448 1506 -hsync +vsync
ModeLine "2560x1440_85" 454.75 2560 2768 3048 3536 1440 1443 1448 1514 -hsync +vsync
ModeLine "2560x1440_96" 400.00 2560 2608 2640 2744 1440 1443 1448 1512 +hsync +vsync
ModeLine "2560x1440_100" 400.00 2560 2608 2640 2720 1440 1443 1448 1481 +hsync +vsync
ModeLine "2560x1440_100" 542.25 2560 2776 3056 3552 1440 1443 1448 1527 -hsync +vsync
ModeLine "2560x1440_120" 661.25 2560 2784 3064 3568 1440 1443 1448 1545 -hsync +vsync
EndSection
Section "Monitor"
# HorizSync 88.8 - 160.0
# VertRefresh 59.5 - 120.0
# HorizSync 28.0 - 55.0
# VertRefresh 43.0 - 72.0
Identifier "Monitor1"
ModelName "CRT-0"
ModeLine "1920x1080_60" 172.80 1920 2040 2248 2576 1080 1081 1084 1118 -hsync +vsync
Option "Enable" "True"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
BoardName "GeForce GTX 660"
BusID "PCI:1:0:0"
Screen 0
Option "Coolbits" "12"
Option "Coolbits" "8"
EndSection
Section "Device"
Driver "nvidia"
BusID "PCI:1:0:0"
Screen 1
EndSection
Section "Screen"
# Removed Option "metamodes" "DVI-I-1: 2560x1440_100 +2560+0, DVI-D-0: 2560x1440_100 +0+0; DVI-I-1: 2560x1440_96 +0+0, DVI-D-0: 2560x1440_96 +2560+0; DVI-I-1: 2560x1440_85 +0+0, DVI-D-0: 2560x1440_85 +2560+0; DVI-I-1: 2560x1440_75 +0+0, DVI-D-0: 2560x1440_75 +2560+0; DVI-I-1: 2560x1440_60 +0+0, DVI-D-0: 2560x1440_60 +2560+0; DVI-I-1: 2560x1440 +0+0, DVI-D-0: 2560x1440 +2560+0"
# Removed Option "metamodes" "DVI-I-1: 1920x1080 +2560+0, DVI-D-0: 2560x1440_100 +0+0"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "UseEDID" "False"
Option "UseEDIDDPI" "False"
Option "UseEDIDFreqs" "False"
Option "ExactModeTimingsDVI" "True"
Option "ModeValidation" "AllowNonEdidModes, AllowNon60hzmodesDFPModes, NoEDIDDFPMaxSizeCheck, NoVertRefreshCheck, NoHorizSyncCheck, NoDFPNativeResolutionCheck, NoMaxSizeCheck, NoMaxPClkCheck, NoEDIDModes"
Option "TwinView" "0"
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-3"
Option "metamodes" "DVI-D-0: 2560x1440_100 +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
# Removed Option "metamodes" "DVI-I-1: 1920x1080_60.00 +2560+0"
# Removed Option "metamodes" "DVI-I-1: 1920x1080_60 +0+0"
# Removed Option "metamodes" "DVI-I-0: 1920x1080 +0+0"
# Removed Option "metamodes" "DVI-I-1: 1024x768 +0+0"
# Removed Option "metamodes" "DVI-I-1: nvidia-auto-select +0+0"
# Removed Option "metamodes" "DVI-I-0: 1400x1050 +0+0"
Identifier "Screen1"
Device "Device1"
Monitor "Monitor1"
DefaultDepth 24
Option "ModeValidation" "AllowNonEdidModes, AllowNon60hzmodesDFPModes, NoEDIDDFPMaxSizeCheck, NoDFPNativeResolutionCheck, NoMaxSizeCheck, NoMaxPClkCheck, NoEDIDModes"
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "CRT-0"
Option "metamodes" "DVI-I-0: 1920x1080_60 +0+0"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "Composite" "Disable"
EndSection
I’ve tried a variety of settings, but none have worked.
