5V Fan Power Consumption
What is maximum +5V power consumption of fan recommended for use with Jetson Orin Nano?
Hi, we don’t have such recommendation. The fan power consumption depends on your fan request. The 5V supply is from DC jack or USB port directly.
Can you provide me with a recommended fan for the Jetson Orin Nano that has a listed max current or max input power spec at 5V?
Can any USB port be used? If not, please specify which USB ports are acceptable.
You can check with the vendors in ecosystem: https://developer.nvidia.com/embedded/ecosystem
