Is it possible to setup 7 cameras to Jetson TX2? We will use 6 cameras of Leopard Imaging(LI-JETSON-KIT-IMX265M12-H) and 1 IP cam using the Ethernet port of Jetson TX2. Thank you in advance!
Yes, but argus not support IP cam though.
Hi ShaneCCC,
Thank you for your response. Do you mean I cannot use IP cam on Jetson TX2?
No, I mean there is no problem to use IP cam on TX2.
Thank you ShaneCCC!
