about using multip camera
I am a new user of Jetson TX1, and now I want to multip camera for my test case, I have some questions, can you help to comments? thanks in advanced!
  1. From the trainning video, it shows that TX1 board support up to 6 sets of camera, right? 1 on-board camera + 5 usb camera?
  2. Is there any special requirement/limitation for the usb camera? or only some models are support?
  3. Is there sample code for the multip camera testing?
The Jetson TX1 board is capable of supporting upto 6 camera’s that can be interfaced with the board. There is a product which supports multiple camera interface with the J22 connector on the Jetson TX1 - e-CAM30_HEXCUTX1. Kindly refer the link below for more details:
The board uses CSI - 2 MIPI interface and supports synchronous frame capture using an external trigger.
The release package along with this board contains a sample source code to capture still images at selected resolutions. For further discussions contact camerasolutions@e-consystems.com
