Hello all…
I use CUDA template project to create a new project named “main_test”
It compiled successfully…
Then I want to add a new *.cu file written by my friend …because I need to call a new function of new *.cu…
I used VS 2005 to add the new *.cu file … and called the new function successfully…
There’s no problem from compiling, and it’s ok to m run my project…
But… I set the breaking point in the new *.cu file, and run Debyg mode…
The program will not stop on that breakpoint …
I checked the new *.cu file and found an information said “the breakpoint will not currently be hit, No symbols have been loaded for this document” wacko.gif
What’s wrong with my project…
I tried to create a new project (even use CUDA winzard 2005) , but it still can’t run anymore…
Does anyone knoww about this problem…???
