Hi…
The link below discusses HDMI HPD on Jetson Nano.
Like the Nano above, when a plug-in is detected in AGX orin, does HDMI HPD drop to low?
Thanks,
Raymond Lee
Hi…
Thanks,
Raymond Lee
It depends on level shift: Level shifters required on DDC/HPD. Orin module pads are not 5V tolerant and cannot directly meet HDMI VIL/VIH requirements. HPD level shifter can be non-inverting or inverting.
On devkit, it should be high.
Hi Trumany…
So when the sink is plugged in, we just need to apply high to the HPD of the AGX orin module?
Thanks,
Raymond Lee
Hi…
The gist of the question is whether I need to pull a high (logic high) to the hpd pin to tell the AGX orin module that the sink is plugged in.
Thanks,
Raymond
Yes, for devkit, HPD should be high when display plug in.
Hi Trumany…
Let me ask again just to confirm…
Your comment just above is that HDMI HPD of AGX Orin is Active high, right?
Thanks,
Raymond Lee
Hi Trumany…
The reason I keep asking is because it seems that when you plug in an HDP into an HDMI Sink (monitor) in the AGX Orin’s DG circuit, the HPD signal of the AGX Orin module is inverted through the FET.
Thanks,
Raymond Lee
I mean it should be high at the pin of HDMI connector when display plug in.
