We evaluated the sparse optical flow by the following method on Orin:
Here is the results of three test datasets by the same PyrLK parameters:
These results show that vpiSubmitOpticalFlowPyrLK() systemically has larger errors comparing with its peers: cv::cudaSparsePyrLkOpticalFlow() and cv::calcOpticalFlowPyrLK(). Our question is that is it normal or we made some mistakes on parameter settings?
Thanks,
Moving this to the Jetson category for visibility.
Discussions relating to the Jetson DevKits and other Embedded computing devices
Do you have sources/instructions to reproduce this issue?
So we can check this with our internal team?
Hi Tom, Thanks for reply. Yes, i just created a public repo at:
Contribute to shunguang/opt-flow-evaluation development by creating an account on GitHub.
you can check out our source code and datasets to repeat this work
Just want to confirm the environment as well.
Which JetPack version do you use? Is it JetPack 5.1.2?
nvidia@nvdia-desktop:~$ sudo apt-cache show nvidia-jetpack
Package: nvidia-jetpack
Version: 5.0.2-b231
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-jetpack-runtime (= 5.0.2-b231), nvidia-jetpack-dev (= 5.0.2-b231)
Homepage: Jetson - Embedded AI Computing Platform | NVIDIA Developer
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_5.0.2-b231_arm64.deb
SHA256: b1268b2cb969e677163f291967bc7542371a29d536379df3f7dfa1f247ff3fab
SHA1: 7ff288a771b83eec8f80a41ccf0eec490f32e10a
MD5sum: 5cc57807b33630d8edb249e53daf58ed
Description: NVIDIA Jetpack Meta Package
Description-md5: ad1462289bdbc54909ae109d1d32c0a
Would you mind testing this on the latest JetPack 5.1.2?
Usually, enhancement won’t backport to the previous release.
Thanks,
Does 5.1.2 update nv-vpi libs?
Hi Aasta, Thanks for the suggestion, I am wondering if you have NVIDIA internal nv-vpi sparse optical flow accuracy test report?
Best wishes!
Finally I had a chance to update my JetPack to 5.1.2, and redo the process. The results are identical with the previously posted plots.
Thanks for the testing.
We will check this issue with our internal team and get back to you.
We don’t guarantee that our result will be aligned with the OpenCV’s output.
However, there are several parameters in the Pyramidal LK Optical Flow.
Have you tried to tune them?
For example, how many pyramid levels are you using for VPI? Is it the same as OpenCV?
Yes, I used the same parameters as that in opencv PryLK algorithm. Do you have an internal evaluation document to share? I am just curious how do you engineers evaluate it? Thanks a lot!
We cannot share internal evaluations and reports here.
But we can check if any info for you with our internal team.
