Add Camera to Franka hand
Isaac Sim Version
4.2.0
Detailed Description
I am trying to add an inhand camera to Franka end effector based on the example simple_stack.
I have tried https://forums.developer.nvidia.com/t/attach-a-camera-to-franka-robot/202248
and How to permanently attach the camera on Franka Panda End Effector - Omniverse / Isaac Sim - NVIDIA Developer Forums.
And got similar error.
My own implementation looks like:
from omni.isaac.sensor import Camera
    async def setup_post_load(self):
        self._create_cams('World/Franka')
    def _create_cams(self, prim_path):
            hand_path = f"{prim_path}/panda_hand"
            self.inhand_cam = Camera(prim_path=f"{hand_path}/inhand_camera", ...),
But while running, the path to the franka is not found.
The error report looks like this:
File “c:/users/username/appdata/local/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.examples/omni/isaac/examples/simple_stack/simple_stack.py”, line 49, in setup_post_load
self._create_cams(‘World/Franka’)
File “c:/users/username/appdata/local/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.examples/omni/isaac/examples/simple_stack/simple_stack.py”, line 76, in create_cams
self.camera = prims.create_prim(
File “c:/users/username/appdata/local/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.core/omni/isaac/core/utils/prims.py”, line 709, in create_prim
prim = define_prim(prim_path=prim_path, prim_type=prim_type)
File “c:/users/username/appdata/local/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.core/omni/isaac/core/utils/prims.py”, line 207, in define_prim
return get_current_stage(fabric=fabric).DefinePrim(prim_path, prim_type)
pxr.Tf.ErrorException:
Error in 'pxrInternal_v0_22__pxrReserved
::UsdStage::_IsValidPathForCreatingPrim’ at line 3340 in file C:\g\97199581\USD\pxr\usd\usd\stage.cpp : ‘Path must be an absolute path: <World/Franka/panda_hand/Camera>’
How should i correctly attach an Camera to a franka? Please teach me.
can you try to change your camera path from 'World/Franka' to '/World/Franka' and see if this works?
I think the missing / at the beginning is causing the ‘Path must be an absolute path: <World/Franka/panda_hand/Camera>’error.
