Hi, recently I bought ADLINK DLAP-211-JNX (Xavier NX). I downloaded sdkmanager to Ubuntu 20.04 Host Computer and try the install Ubuntu 20.04 with JetPack 5.1.3. I put my 128 GB SD Card with my SD Card Reader to the port and started the flash but after install Ubuntu to it’s 16 GB SD Card, it says no enough space for CUDA etc… I searched for solutions then I saw my jetson doesn’t see the new 128 GB SD Card. Then I tried to install with my M.2 2242 SSD but when I insert my SSD to the slot and give power to my Jetson, the power button -which lights up when the system is turned on- isn’t turning on. Can you give me any advice please? Thanks in advance…
Hi cagiranyigitbora,
It seems you are using the custom carrier board so that please ask your vendor for the custom BSP package and use the flash command for your board.
SDK Manager should only be available for the devkit since we don’t know how they design the board.
Please also check if there’s serial console log could be shared for further check.
