Afeter try to update, jetpack 6.2.2, No boot no display
After try to update my jetson nano- origin.
The sistem don’t boot and don’t show display.
After trying to load the system with the SDK manager.
It show and error, durring the last step.
Hi @edlopsilv,
Could you please confirm:
  1. Are you using a Jetson Orin Nano or the original Jetson Nano?
  2. Is it an NVIDIA developer kit or a third-party carrier board?
  3. Which JetPack version worked before the update, and how did you initially update to JetPack 6.2.2?
Btw, if you’re using the NVIDIA Jetson Orin Nano developer kit, please also attach the ZIP from SDK Manager’s Export Debug Logs for the failed installation.
Sure, is a Jetson Origin Nano developer kit.
It was working with the 5.1.3 version.
Thanks for the support.
SDKM_logs_JetPack_5.1.6_Linux_for_Jetson_Orin_Nano_modules_2026-09-16_20-22-23.zip (2.5 MB)
Hi @edlopsilv,
The logs show that flashing failed while processing the partition table on the microSD card.
Could you please:
  1. Confirm the capacity of the microSD card used in this attempt?
  2. Try flashing with another known-good microSD card using the same SDK Manager settings, and let us know its capacity and whether the same error occurs?
Please back up any data on the replacement card first, as flashing will erase it.
Hi @wichiu
The original microSD card had a capacity of 32 GB. I swapped it for a 64 GB card while maintaining the same SDK Manager settings, but I am still encountering the same error.
Attached are the logs for reference.
Best regards.
SDKM_logs_JetPack_5.1.6_Linux_for_Jetson_Orin_Nano_modules_2026-09-23_16-43-59.zip (1.9 MB)
@wichiu
After using SDK Manager to install JetPack 6.2.3, I can access the Jetson using a USB-to-TTL converter.
What is the procedure to use the DisplayPort again?
Hi @edlopsilv,
Your screenshot shows that Ubuntu is booting. Help me check whether the graphical login service is running.
Please run the following commands through the UART console and share the output:
cat /etc/nv_tegra_release
systemctl status display-manager --no-pager -l
Also, are you connecting the monitor directly through DisplayPort or using an adapter?
Hi. @wichiu
Here are the screenshots of the command outputs. I am connecting the monitor through an adapter that worked in the past.
Could you try connecting monitor directly with a known-good DP cable, without the adapter?
Btw, your output shows L4T 36.4.4, which corresponds to JetPack 6.2.1 not 6.2.2.
