My Jetson Orin Nano no longer boots after upgrading JetPack from 5.x to 6.x.
Upgrade details
JetPack 5.x was originally flashed to a microSD
The system worked correctly on JetPack 5
JetPack 6.x was installed by upgrading the existing system
No clean flash and no SDK Manager flashing was used
Problem
On power-up, the bootloader menu appears normally
After that, the screen becomes completely black
Ubuntu never starts (no splash, no login)
The board stays powered on but does not finish booting
Environment
Board: Jetson Orin Nano
Storage: microSD
Display: HDMI (working monitor)
Questions
Is upgrading JetPack 5 → 6 in-place supported on Orin Nano?
Is a clean re-flash required for JetPack 6?
How can I debug or recover this (UART logs, recovery mode)?
Thank you for your help.
