Hello Jetson community, I’m having a critical boot issue with my Jetson Orin Nano Developer Kit after trying to switch between different JetPack versions on SD cards. What happened (chronological order):
1. ✅ SD Card #1 with JetPack 6.2 - Worked perfectly
2. ❌ SD Card #2 with JetPack 5.2 - Stuck in boot loop, couldn’t start
3. ✅ Back to SD Card #1 (JetPack 6.2) - Still worked fine
4. ❌ SD Card #3 with JetPack 5.1 - Didn’t work
5. ❌ Back to SD Card #1 (JetPack 6.2) - Now BLACK SCREEN! Fan spins up then stops, then runs continuously. Screen shows only a blinking cursor/dash.
My original goal: I need to run JetPack 5.1 to use an IMX519 camera which according to the supplier’s documentation is only compatible with JetPack 5.1 and NOT compatible with JetPack 6.2.
How can I reset the bootloader to factory state so I can get JetPack 6.2 working again?
What’s the correct command to flash only the bootloader without installing a full OS to eMMC?
