After Power On/Off test several time , the file system mmcbl0p1 can't mount
xavier nx emmc module , after power on/ off test several time , some module can’t mount file system .
attach file is the system log .
I can’t find the e2fsck command , how can I repair the ext4 fliesystem ?
system_crash.txt (72.1 KB)
I don’t know about on a Jetson, but it is possible that if you hit CTRL-c, then it might drop you into an interactive console, either on regular keyboard/monitor or perhaps on serial console.
If you have a problem and really need to save the install, then you could clone the rootfs, repair the clone on your desktop Linux PC, and then flash the repaired clone back in place (warning: requires lots of time and disk space on the PC).
