How to use CPHY IMX318 on AGX
Have reference to imx318, below is the device tree configure.
…/hardware/nvidia/platform/t19x/common/kernel-dts/t19x-common-modules/tegra194-camera-e3331-a00.dtsi
imx318dtsi
imx318.dtsi (11.5 KB)
Figure out the log
[ 479.309079] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 479.309242] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 479.310611] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 479.386055] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
Get the trace log to check if any clue.
- I want to verify CPHY on AGX, is there any good recommendation
Maybe get CPHY sensor board from partner.
tegra194-camera-e3331-a00.dtsi (8.4 KB)
Is the device tree configuration for this file 3trio? How do I change the device tree if I want to test 2TRIO?
You need to modify the csi5_fops.c due to below code.
bool is_cphy = (csi_lanes == 3);
host1x {
vi@15c10000 {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
e3331_vi_in0: endpoint {
port-index = <0>;
bus-width = <3>;
remote-endpoint = <&e3331_csi_out0>;
nvcsi@15a00000 {
num-channels = <1>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3331_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <3>;
remote-endpoint = <&e3331_imx318_out0>;
port@1 {
reg = <1>;
e3331_csi_out0: endpoint@1 {
remote-endpoint = <&e3331_vi_in0>;
i2c@3180000 {
tca9546@70 {
i2c@0 {
imx318_a@10 {
compatible = "nvidia,imx318";
reg = <0x10>;
/* Physical dimensions of sensor */
physical_w = "6.811";
physical_h = "5.254";
sensor_model = "imx318";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
avdd-reg = "vana";
iovdd-reg = "vif";
dvdd-reg = "vdig";
has-eeprom;
* ==== Modes ====
* A modeX node is required to support v4l2 driver
* implementation with NVIDIA camera software stack
* == Signal properties ==
* phy_mode = "";
* PHY mode used by the MIPI lanes for this device
* tegra_sinterface = "";
* CSI Serial interface connected to tegra
* Incase of virtual HW devices, use virtual
* For SW emulated devices, use host
* pix_clk_hz = "";
* Sensor pixel clock used for calculations like exposure and framerate
* readout_orientation = "0";
* Based on camera module orientation.
* Only change readout_orientation if you specifically
* Program a different readout order for this mode
* == Image format Properties ==
* active_w = "";
* Pixel active region width
* active_h = "";
* Pixel active region height
* pixel_t = "";
* The sensor readout pixel pattern
* line_length = "";
* Pixel line length (width) for sensor mode.
* == Source Control Settings ==
* Gain factor used to convert fixed point integer to float
* Gain range [min_gain/gain_factor, max_gain/gain_factor]
* Gain step [step_gain/gain_factor is the smallest step that can be configured]
* Default gain [Default gain to be initialized for the control.
* use min_gain_val as default for optimal results]
* Framerate factor used to convert fixed point integer to float
* Framerate range [min_framerate/framerate_factor, max_framerate/framerate_factor]
* Framerate step [step_framerate/framerate_factor is the smallest step that can be configured]
* Default Framerate [Default framerate to be initialized for the control.
* use max_framerate to get required performance]
* Exposure factor used to convert fixed point integer to float
* For convenience use 1 sec = 1000000us as conversion factor
* Exposure range [min_exp_time/exposure_factor, max_exp_time/exposure_factor]
* Exposure step [step_exp_time/exposure_factor is the smallest step that can be configured]
* Default Exposure Time [Default exposure to be initialized for the control.
* Set default exposure based on the default_framerate for optimal exposure settings]
* gain_factor = ""; (integer factor used for floating to fixed point conversion)
* min_gain_val = ""; (ceil to integer)
* max_gain_val = ""; (ceil to integer)
* step_gain_val = ""; (ceil to integer)
* default_gain = ""; (ceil to integer)
* Gain limits for mode
* exposure_factor = ""; (integer factor used for floating to fixed point conversion)
* min_exp_time = ""; (ceil to integer)
* max_exp_time = ""; (ceil to integer)
* step_exp_time = ""; (ceil to integer)
* default_exp_time = ""; (ceil to integer)
* Exposure Time limits for mode (sec)
* framerate_factor = ""; (integer factor used for floating to fixed point conversion)
* min_framerate = ""; (ceil to integer)
* max_framerate = ""; (ceil to integer)
* step_framerate = ""; (ceil to integer)
* default_framerate = ""; (ceil to integer)
* Framerate limits for mode (fps)
* embedded_metadata_height = "";
* Sensor embedded metadata height in units of rows.
* If sensor does not support embedded metadata value should be 0.
mode0 { /*IMX318_MODE_5488X4112_30FPS*/
mclk_khz = "24000";
num_lanes = "3";
phy_mode = "CPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "20";
active_w = "5488";
active_h = "4112";
mode_type = "bayer";
pixel_phase = "bggr";
csi_pixel_bit_depth = "10";
line_length = "5488";
inherent_gain = "1";
mclk_multiplier = "31.25";
pix_clk_hz = "750000000";
gain_factor = "16";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = "16"; /* 1.0 */
max_gain_val = "256"; /* 16.0 */
step_gain_val = "1"; /* 0.125 */
default_gain = "16";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "1500000"; /* 1.5 */
max_framerate = "30000000"; /* 30 */
step_framerate = "1";
default_framerate= "30000000";
min_exp_time = "34"; /* us */
max_exp_time = "550385"; /* us */
step_exp_time = "1";
default_exp_time = "33334";/* us */
embedded_metadata_height = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3331_imx318_out0: endpoint {
port-index = <0>;
bus-width = <3>;
remote-endpoint = <&e3331_csi_in0>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* Set this to the highest pix_clk_hz out of all available modes.
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <3>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <800000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. 鈥渞ear鈥?or 鈥渇ront鈥?
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module0 {
badge = "e3331_rear_22N02A";
position = "rear";
orientation = "1";
drivernode0 {
pcl_id = "v4l2_sensor";
devname = "imx318 30-0010";
proc-device-tree = "/proc/device-tree/i2c@3180000/tca9546@70/i2c@0/imx318_a@10";
- Don’t you need to modify the device tree
Yes, device tree must have modify.
