Hi, I am debugging a image sensor module called imx586, the resolution is 8000X6000, the sensor’s register has been configured successfully, 4 lanes of sensor hardware MIPI signaling are all outputting normally, but when I ran the command:
v4l2-ctl --set-fmt-video=width=8000,height=6000,pixelformat=RG10 --stream-mmap --stream-count=1 -d /dev/video0 --stream-to=imx586.raw
there was the following mistake:
[ 288.549036] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 37748832
[ 288.550293] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 16384
[ 288.705029] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 37748832
[ 288.706290] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 16384
[ 288.861034] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 37748832
[ 289.017028] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 37748832
[ 289.018376] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 16384
[ 289.173068] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 37748832
[ 289.174338] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 16384
[ 289.329075] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 37748832
[ 289.485054] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 37748832
[ 289.486322] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 16384
The dts file I use is:
host1x {
vi@15c10000 {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
e3326_vi_in0: endpoint {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&e3326_csi_out0>;
nvcsi@15a00000 {
num-channels = <1>;
#size-cells = <0>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3326_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&e3326_imx586_out0>;
port@1 {
reg = <1>;
e3326_csi_out0: endpoint@1 {
remote-endpoint = <&e3326_vi_in0>;
i2c@3180000 {
imx586_c@1a {
compatible = "nvidia,imx586";
/* I2C device address */
reg = <0x1a>;
/* V4L2 device node location */
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "7.504";
physical_h = "5.659";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
avdd-reg = "vana";
iovdd-reg = "vif";
/* Sensor output flip settings */
vertical-flip = "true";
* A modeX node is required to support v4l2 driver
* implementation with NVIDIA camera software stack
* mclk_khz = "";
* Standard MIPI driving clock, typically 24MHz
* num_lanes = "";
* Number of lane channels sensor is programmed to output
* tegra_sinterface = "";
* The base tegra serial interface lanes are connected to
* Incase of virtual HW devices, use virtual
* For SW emulated devices, use host
* phy_mode = "";
* PHY mode used by the MIPI lanes for this device
* discontinuous_clk = "";
* The sensor is programmed to use a discontinuous clock on MIPI lanes
* dpcm_enable = "true";
* The sensor is programmed to use a DPCM modes
* cil_settletime = "";
* MIPI lane settle time value.
* A "0" value attempts to autocalibrate based on mclk_multiplier
* active_w = "";
* Pixel active region width
* active_h = "";
* Pixel active region height
* pixel_t = "";
* The sensor readout pixel pattern
* readout_orientation = "0";
* Based on camera module orientation.
* Only change readout_orientation if you specifically
* Program a different readout order for this mode
* line_length = "";
* Pixel line length (width) for sensor mode.
* This is used to calibrate features in our camera stack.
* mclk_multiplier = "";
* Multiplier to MCLK to help time hardware capture sequence
* TODO: Assign to PLL_Multiplier as well until fixed in core
* pix_clk_hz = "";
* Sensor pixel clock used for calculations like exposure and framerate
* inherent_gain = "";
* Gain obtained inherently from mode (ie. pixel binning)
* == Source Control Settings ==
* Gain factor used to convert fixed point integer to float
* Gain range [min_gain/gain_factor, max_gain/gain_factor]
* Gain step [step_gain/gain_factor is the smallest step that can be configured]
* Default gain [Default gain to be initialized for the control.
* use min_gain_val as default for optimal results]
* Framerate factor used to convert fixed point integer to float
* Framerate range [min_framerate/framerate_factor, max_framerate/framerate_factor]
* Framerate step [step_framerate/framerate_factor is the smallest step that can be configured]
* Default Framerate [Default framerate to be initialized for the control.
* use max_framerate to get required performance]
* Exposure factor used to convert fixed point integer to float
* For convenience use 1 sec = 1000000us as conversion factor
* Exposure range [min_exp_time/exposure_factor, max_exp_time/exposure_factor]
* Exposure step [step_exp_time/exposure_factor is the smallest step that can be configured]
* Default Exposure Time [Default exposure to be initialized for the control.
* Set default exposure based on the default_framerate for optimal exposure settings]
* gain_factor = ""; (integer factor used for floating to fixed point conversion)
* min_gain_val = ""; (ceil to integer)
* max_gain_val = ""; (ceil to integer)
* step_gain_val = ""; (ceil to integer)
* default_gain = ""; (ceil to integer)
* Gain limits for mode
* exposure_factor = ""; (integer factor used for floating to fixed point conversion)
* min_exp_time = ""; (ceil to integer)
* max_exp_time = ""; (ceil to integer)
* step_exp_time = ""; (ceil to integer)
* default_exp_time = ""; (ceil to integer)
* Exposure Time limits for mode (us)
* min_hdr_ratio = "";
* max_hdr_ratio = "";
* HDR Ratio limits for mode
* framerate_factor = ""; (integer factor used for floating to fixed point conversion)
* min_framerate = "";
* max_framerate = "";
* step_framerate = ""; (ceil to integer)
* default_framerate = ""; (ceil to integer)
* Framerate limits for mode (fps)
mode0 { // imx586_MODE_8000X6000
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
discontinuous_clk = "yes";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "8000";
active_h = "6000";
mode_type = "bayer";
pixel_phase = "rggb";
csi_pixel_bit_depth = "10";
line_length = "8000";
inherent_gain = "1";
mclk_multiplier = "60";
pix_clk_hz = "1440000000";
gain_factor = "10";
min_gain_val = "10";/* 1DB*/
max_gain_val = "160";/* 16DB*/
step_gain_val = "1";
default_gain = "10";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "1816577";/*1.816577 */
max_framerate = "30000000";/*30*/
step_framerate = "1";
default_framerate = "30000000";
exposure_factor = "1000000";
min_exp_time = "34";/* us */
max_exp_time = "550385";/* us */
step_exp_time = "1";
default_exp_time = "33334";/* us */
embedded_metadata_height = "0";
mode1 { //imx586_MODE_2592X1458
mclk_khz = "24000";
num_lanes = "4";
tegra_sinterface = "serial_c";
phy_mode = "DPHY";
active_w = "8000";
active_h = "6000";
line_length = "8200";
mclk_multiplier = "6.67";
pix_clk_hz = "160000000";
gain_factor = "10";
mode2 { //IMX586_MODE_1280X720
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1280";
active_h = "720";
pixel_phase = "bggr";
line_length = "1752";
gain_factor = "10";
min_framerate = "2787078";/* 2.787078 */
max_framerate = "120000000";/* 120*/
default_framerate = "120000000";
min_exp_time = "22";/* us */
max_exp_time = "358733";/* us */
default_exp_time = "8334";/* us */
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3326_imx586_out0: endpoint {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&e3326_csi_in0>;
e3326_lens_imx586@P5V27C {
min_focus_distance = "0.0";
hyper_focal = "0.0";
focal_length = "2.67";
f_number = "2.0";
aperture = "2.0";
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <4>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <160000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. “rear” or “front”.
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module0 {
badge = "e3326_front_P5V27C";
position = "rear";
orientation = "1";
drivernode0 {
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver v4l2 device name */
devname = "imx586 2-001a";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@3180000/imx586_c@1a";
drivernode1 {
pcl_id = "v4l2_lens";
proc-device-tree = "/proc/device-tree/e3326_lens_imx586@P5V27C/";
Anyone knows what are the possible causes?
Thank you!
