AGX Orin UPHY to Ethernet
For AGX ORIN SOM based design can I connect the UPHY lines directly to the USXGMII MAC lines of a different compute chip (RX-tX and TX-RX)? Can XFI And USXGMII lines be used interchangeably?
I want to avoid using a PHY to convert to base-T and repeat it again
Hi, I don’t think that works since it is not validated. We don’t support other designs than those in the DG.
