Agx xavier development kit booting issue_no booting
Synchronous Exception at 0x000000087AA3DB9C
ASSERT [ArmCpuDxe] /out/nvidia/bootloader/uefi/Jetson_RELEASE/edk2/ArmPkg/Libra)
Resetting the system in 5 seconds.
����Shutdown state requested 1
Rebooting system …
[0000.054] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level .
[0000.062] I> MB1 (prd-version: 2.6.0.0-t194-41334769-cab45716)
[0000.068] I> Boot-mode: Coldboot
[0000.071] I> Platform: Silicon
[0000.073] I> Chip revision : A02P
[0000.076] I> Bootrom patch version : 15 (correctly patched)
[0000.082] I> ATE fuse revision : 0x200
[0000.085] I> Ram repair fuse : 0x0
[0000.088] I> Ram Code : 0x2
[0000.091] I> rst_source: 0xb, rst_level: 0x1
[0000.096] I> Boot-device: SDMMC (instance: 3)
[0000.112] I> sdmmc DDR50 mode
[0000.115] I> Boot chain mechanism: A/B
[0000.119] I> Current Boot-Chain Slot: 1
[0000.122] E> Error, current slot 1 fails: sr_bl: 0x4d04ef1, sr_br: 0x1
[0000.129] I> Reset to recovery mode
no display, no booting
how can I resolve this issues? please help me
It seems that the assertion error might have been truncated.
Please record the entire serial console log for our review using the following command:
sudo minicom -C ./serial_log.txt -D /dev/ttyACM${your port} -8 -b 115200 B
Please refer to the attached file.
serial_log.txt (25.6 KB)
Please try flashing the latest JP version 5.1.6 to check whether issue exists.
I can not install os and jp neither.
Factory mode is not available in this time.
No usb is available except debug port.
Let me know how to to it.
How can I reset to default bios setup in this situation?
Please let me know how to resolve this issue.
As you see the debug port log file.
Agx xavier stop after reboot.
I can not enter the bios setup and factory recovery mode either.
Can you help me how to install JP in the situation.
Thank you for your support in advance.
Reflashing is the only option since you can’t access either the UEFI or the system.
How can I refreshing my board?
I will prepare things needed for that.
Thank you for your reply.
We recommend to install sdk manager to full flash the device.
SDK manager can not detect device via usb. The device’s usb is not shown in host pc.
Do you have manual for flashing nand in device using jtag ( j-link )?
Thank you for your supports.
Did you put the board into recovery mode before your flash attempt?
If you didn’t do that then sdkm won’t detect your board for sure.
Yes, I did. But, no usb device is found from the host.
Only I can see the log attached via debug port. ( mini usb, not usb c)
That’s why I can not re-flash the board.
Are you talking about the board still gives you log even though you already tried the recovery mode steps?
Yes, logs from micro usb. No respond from c type usb.
How did you put the board into recovery mode? Sounds like we should review your steps.
if the debug port is outputted, it may not enter recovery mode. I will check if there is a problem with the recovery button. Thank you for your quick response and it helped to define the problem.
