Hello linuxdev,
My application is a bare metal application (hypervisor type 1) which is executed properly by u-boot in other configuration (TX1 for example).
By the way i create my binary image and run mkbootimg to comply to cboot expectation (especially tegrabl_verify_boot_img_hdr).
During execution i get the following output:
8—
[0002.166] I> Load in CBoot Boot Options partition and parse it
[0002.177] I> boot-order :-
[0002.177] I> 1.net
[0002.177] I> 2.sd
[0002.177] I> 3.usb
[0002.178] I> 4.nvme
[0002.180] I> 5.emmc
[0002.182] I> tftp-server-ip: 192.168.0.1
[0002.186] I> static-ip: 192.168.0.10
[0002.190] I> ip-netmask: 255.255.255.0
[0002.193] I> ip-gateway: 192.168.0.1
[0002.197] E> Failed to parse GUID
[0002.200] I> Hit any key to stop autoboot: 4 3 2 1
[0004.207] initializing target
[0004.207] calling apps_init()
[0004.208] starting app kernel_boot_app
[0004.227] I> found decompressor handler: lz4-legacy
[0004.228] I> decompressing BMP blob …
[0004.239] I> Kernel type = Normal
[0004.240] I> Loading kernel-bootctrl from partition
[0004.240] I> Loading partition kernel-bootctrl at 0xa42c0000 from device(0x1)
[0004.247] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.247] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.248] I> ########## Net boot ##########
[0004.248] I> EQoS: Init
[0006.252] I> Wait till auto-calibration completes…
[0006.253] I> Configuring PHY
[0006.313] I> Start auto-negotiation
[0006.314] I> Wait till it completes…
[0009.315] I> MAC addr 00:04:4b:cb:9f:3d
[0009.315] I> Configure Static IP …
[0009.315] I> netif status changed 192.168.0.10
[0009.316] I> netif status changed 192.168.0.10
[0009.316] I> Our IP: 192.168.0.10
[0009.316] TFTP Client: Init
[0009.317] TFTP Client: Server IP: 192.168.0.1
[0009.317] TFTP Client: Send RRQ, file: jetson.dtb
[0014.321] TFTP Client: Connection failed
[0014.331] TFTP Client: Send RRQ, file: jetson.dtb
[0014.399] TFTP Client: Last packet received
[0014.400] TFTP Client: Send RRQ, file: boot.img
[0014.754] TFTP Client: Last packet received
[0014.755] I> netif status changed 192.168.0.10
[0014.756] I> Validate kernel …
[0014.756] I> Validate kernel-dtb …
[0014.756] I> Checking boot.img header magic … [0014.756] I> [OK]
[0014.757] I> Kernel hdr @0xa42c0000
[0014.757] I> Kernel dtb @0x90000000
[0014.757] I> decompressor handler not found
[0014.761] I> Copying kernel image (1610664 bytes) from 0xa42c0800 to 0x80080000 … [0014.769] I> Done
[0014.770] I> Move ramdisk (len: 0) from 0xa444a000 to 0x91000000
[0014.776] I> Updated bpmp info to DTB
[0014.780] I> Ramdisk: Base: 0x91000000; Size: 0x0
[0014.784] I> Updated initrd info to DTB
[0014.787] W> WARN: Fail to override “console=none” in commandline
[0014.793] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0014.801] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0014.808] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0014.815] W> No valid slot number is found in scratch register
[0014.821] W> Return default slot: _a
[0014.824] I> Active slot suffix:
[0014.827] I> add_boot_slot_suffix: slot_suffix =
[0014.832] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168
000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_te
gra.en_boot_part_access=1
[0014.857] I> Updated bootarg info to DTB
[0014.860] W> MAC addr invalid!
[0014.863] E> Failed to get WIFI MAC address
[0014.867] W> MAC addr invalid!
[0014.870] E> Failed to get Bluetooth MAC address
[0014.875] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:cb:9f:3d
[0014.881] E> “plugin-manager” doesn’t exist, creating
[0014.886] I> Adding /chosen/plugin-manager/cvm
[0014.890] E> “chip-id” doesn’t exist, creating
[0014.894] I> Adding /chosen/plugin-manager/chip-id
[0014.899] E> “configs” doesn’t exist, creating
[0014.903] I> Adding /chosen/plugin-manager/configs
[0014.908] E> “ids” doesn’t exist, creating
[0014.912] I> Adding /chosen/plugin-manager/ids
[0014.916] E> “odm-data” doesn’t exist, creating
[0014.920] I> Adding /chosen/plugin-manager/odm-data
[0014.928] E> “memory” doesn’t exist, creating
[0014.930] I> [0] START: 0x80000000, END: 0xac000000
[0014.934] I> [1] START: 0xac004000, END: 0xf0ad0000
[0014.939] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0014.943] I> dram_block larger than 80000000
[0014.947] I> [3] START: 0x100000000, END: 0x480000000
[0014.952] I> added [base:0x80000000, size:0x2c000000] to /memory
[0014.958] I> added [base:0xac200000, size:0x44800000] to /memory
[0014.964] I> added [base:0x100000000, size:0x380000000] to /memory
[0014.971] I> Updated memory info to DTB
[0014.974] E> add_disp_param: failed to get display params for du=0
[0014.980] E> “reset” doesn’t exist, creating
[0014.985] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0014.989] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0014.993] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0014.998] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0015.003] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0015.008] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0015.012] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0015.017] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0015.023] E> “misc-data” doesn’t exist, creating
[0015.026] I> Boot-device: eMMC
[0015.029] I> Add boot-sdmmc to plugin-manager/misc-data
[0015.034] I> Add storage-sdmmc to plugin-manager/misc-data
[0015.040] W> Unknown storage device
[0015.043] I> Add serial number:0423418004115 as DT property
[0015.050] I> Plugin-manager override starting
[0015.053] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0015.060] I> node /plugin-manager/fragement-soft-wdt matches
[0015.068] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0015.072] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0015.083] I> Disable plugin-manager status in FDT
[0015.084] I> Plugin-manager override finished successfully
[0015.085] I> tegrabl_load_kernel_and_dtb: Done
[0015.090] E> tegrabl_display_clear: display is not initialized
[0015.095] W> Boot logo display failed…
[0015.099] I> Kernel EP: 0x80080000, DTB: 0x90000000
[0015.104]
[0015.105] -----------------------------------------------
[0015.110] Synchronous Exception: UNKNOWN EXCEPTION
[0015.115] -----------------------------------------------
[0015.120]
[0015.121] ESR 0x2000000: ec 0x0, il 0x1, iss 0x0
[0015.126] -----------------------------------------------
[0015.131] [Stack Trace]
[0015.133]
[0015.135] => pc:0x80080000, sp:0xA0689740
[0015.138] => pc:0xA0603BEC, sp:0xA0689970
[0015.142] => pc:0xA0603C00, sp:0xA06899E0
[0015.146] => pc:0xA0603884, sp:0xA0689A20
[0015.150] => pc:0xA0602DF8, sp:0xA0689A30
[0015.154] => pc:0xA0602DCC, sp:0xA0689A40
[0015.158] -----------------------------------------------
[0015.163] iframe 0xa0689650:
[0015.166] x0 0x 90000000 x1 0x 0 x2 0x 0 x3 0x 0
[0015.175] x4 0x 80080000 x5 0x 20 x6 0x b200123 x7 0x ffffffc0
[0015.184] x8 0x 0 x9 0xffffffffffffffff x10 0x 6 x11 0x 2
[0015.193] x12 0x 1 x13 0x 40 x14 0x 1 x15 0x 2c0
[0015.202] x16 0x 0 x17 0x 0 x18 0x 0 x19 0x 0
[0015.211] x20 0x a06899f0 x21 0x 0 x22 0x 0 x23 0x 0
[0015.220] x24 0x 0 x25 0x 0 x26 0x 0 x27 0x 0
[0015.229] x28 0x 0 x29 0x a0689970 lr 0x a0603ba0 sp 0x a0689740
[0015.238] elr 0x 80080000
[0015.241] spsr 0x 400003c9
[0015.245] -----------------------------------------------
[0015.250] panic (caller 0xa0601238): die
[0015.254] HALT: spinning forever…
—8
The following line draws my attention
8—
—8
So the expected entry point virtual address is 0x80080000 which is not my case…
When i dig a littel bit into cboot source the function tegrabl_get_kernel_load_addr retrieves the entry point from the boot_params variable.
How can i update boot_params properly to modify my entry point?
