Re-flash the device tree jetson agx xavier
I’m struggling with a new problem.
I’m trying to recompile the code source of the linux of the nvidia jetson xavier agx, to have this source code I execute this script that we can find in the folder linux_tegra/source_sync.sh.
the script create a new folder 'sources/ ’ with all the source. To compile it, I followed this link :
and i just want to flash with the new DTB that i generate with this code source,
To do this i execute the following line :
sudo ./flash.sh -r -k kernel-dtb jetson-xavier mmcblk0p1
When i reset the nvidia, it stay with a black screen and i don’t understand what i did wrong ?
I also tried with this link and the result is the same :
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-322/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2Fkernel_custom.html%23
you can find the log below
ntering main console loop
] ��[0001.249] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.303] I> 13) Base:0x40046000 Size:0x00002000
[0001.308] I> 14) Base:0x40048000 Size:0x00002000
[0001.312] I> 15) Base:0xac000000 Size:0x00004000
[0001.317] I> 16) Base:0x4004a000 Size:0x00002000
[0001.321] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.326] I> 18) Base:0x4004c000 Size:0x00002000
[0001.330] I> 19) Base:0xf2200000 Size:0x00600000
[0001.335] I> 20) Base:0x4004e000 Size:0x00002000
[0001.339] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.344] I> 22) Base:0x00000000 Size:0x00000000
[0001.348] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.353] I> 24) Base:0xf6000000 Size:0x02000000
[0001.357] I> 25) Base:0x40050000 Size:0x00002000
[0001.361] I> 26) Base:0x40040000 Size:0x00006000
[0001.366] I> 27) Base:0xf1800000 Size:0x00400000
[0001.370] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.375] I> 29) Base:0xf1400000 Size:0x00400000
[0001.379] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.384] I> 31) Base:0x00000000 Size:0x00000000
[0001.388] I> 32) Base:0xf8000000 Size:0x08000000
[0001.393] I> 33) Base:0x00000000 Size:0x00000000
[0001.397] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.402] I> 35) Base:0xab000000 Size:0x01000000
[0001.406] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.411] I> 37) Base:0xf2800000 Size:0x00800000
[0001.415] I> 38) Base:0x80000000 Size:0x20000000
[0001.420] I> 39) Base:0xb0000000 Size:0x08000000
[0001.424] I> 40) Base:0x00000000 Size:0x00000000
[0001.428] I> 41) Base:0x00000000 Size:0x00000000
[0001.433] I> 42) Base:0x00000000 Size:0x00000000
[0001.437] I> 43) Base:0x00000000 Size:0x00000000
[0001.442] I> 44) Base:0x00000000 Size:0x00000000
[0001.446] I> 45) Base:0x00000000 Size:0x00000000
[0001.451] GIC-SPI Target CPU: 0
[0001.454] Interrupts Init done
[0001.457] calling constructors
[0001.459] initializing heap
[0001.462] I> Heap: [0xa0691568 ... 0xab000000]
[0001.466] initializing threads
[0001.469] initializing timers
[0001.472] creating bootstrap completion thread
[0001.476] top of bootstrap2()
[0001.479] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.484] initializing platform
[0001.487] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.492] W> device prod register failed
[0001.496] I> Bl_dtb @0xaaf00000
[0001.501] W> "plugin-manager" doesn't exist, creating
[0001.504] W> "ids" doesn't exist, creating
[0001.508] W> "connection" doesn't exist, creating
[0001.512] W> "configs" doesn't exist, creating
[0001.522] I> Find /i2c@3160000's alias i2c0
[0001.522] I> Reading eeprom i2c=0 address=0x50
[0001.550] I> Device at /i2c@3160000:0x50
[0001.551] I> Reading eeprom i2c=0 address=0x56
[0001.551] E> I2C: slave not found in slaves.
[0001.551] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0001.552] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.553] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x000.
[0001.560] E> eeprom: Failed to read I2C slave device
[0001.565] I> Eeprom read failed 0x3526070d
[0001.571] I> Find /i2c@3180000's alias i2c2
[0001.573] I> Reading eeprom i2c=2 address=0x54
[0001.579] E> I2C: slave not found in slaves.
[0001.581] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.589] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.595] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x000.
[0001.604] E> eeprom: Failed to read I2C slave device
[0001.609] I> Eeprom read failed 0x3526070d
[0001.613] I> Reading eeprom i2c=2 address=0x57
[0001.618] E> I2C: slave not found in slaves.
[0001.622] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.629] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.635] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x000.
[0001.644] E> eeprom: Failed to read I2C slave device
[0001.649] I> Eeprom read failed 0x3526070d
[0001.653] I> Reading eeprom i2c=2 address=0x52
[0001.658] E> I2C: slave not found in slaves.
[0001.662] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.670] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.675] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x000.
[0001.685] E> eeprom: Failed to read I2C slave device
[0001.689] I> Eeprom read failed 0x3526070d
[0001.694] I> Find /i2c@c240000's alias i2c1
[0001.697] I> Reading eeprom i2c=1 address=0x52
[0001.703] E> I2C: slave not found in slaves.
[0001.706] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.714] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.719] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x000.
[0001.729] E> eeprom: Retry to read I2C slave device.
[0001.734] E> I2C: slave not found in slaves.
[0001.738] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.745] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.751] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x000.
[0001.760] E> eeprom: Failed to read I2C slave device
[0001.765] I> Eeprom read failed 0x3526070d
[0001.769] I> Reading eeprom i2c=1 address=0x50
[0001.774] E> I2C: slave not found in slaves.
[0001.778] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.786] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.791] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x000.
[0001.801] E> eeprom: Retry to read I2C slave device.
[0001.806] E> I2C: slave not found in slaves.
[0001.809] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.817] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.823] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x000.
[0001.832] E> eeprom: Failed to read I2C slave device
[0001.837] I> Eeprom read failed 0x3526070d
[0001.841] I> create_pm_ids: id: 2888-0001-400-L, len: 15
[0001.846] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch3
[0001.857] I> Adding plugin-manager/ids/2888-0001-400=/i2c@3160000:module@0x50
[0001.865] W> "i2c@3160000" doesn't exist, creating
[0001.869] W> "module@0x50" doesn't exist, creating
[0001.875] I> Adding plugin-manager/cvm
[0001.877] W> "chip-id" doesn't exist, creating
[0001.882] I> Adding plugin-manager/chip-id/A02
[0001.886] I> Plugin-manager override starting
[0001.891] I> Disable plugin-manager status in FDT
[0001.895] I> Plugin-manager override finished successfully
[0001.900] I> gpio framework initialized
[0001.905] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.912] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.919] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.925] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca99
[0001.933] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9
[0001.940] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.946] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.953] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca99
[0001.961] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9
[0001.968] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.975] I> fixed regulator driver initialized
[0001.983] I> register 'maxim' power off handle
[0001.984] I> virtual i2c enabled
[0001.986] I> registered 'maxim,max20024' pmic
[0001.990] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.997] I> Boot-device: eMMC
[0002.000] I> Boot_device: SDMMC_BOOT instance: 3
[0002.008] I> sdmmc-3 params source = boot args
[0002.009] I> create_pm_ids: id: 2888-0001-400-L, len: 15
[0002.014] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch3
[0002.025] I> sdmmc bdev is already initialized
[0002.029] I> sdmmc-3 params source = boot args
[0002.060] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.072] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.079] E> no regulator info present for avdd_hdmi-supply
[0002.079] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.082] E> no regulator info present for avdd_hdmi-supply
[0002.083] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.084] E> cannot find any other nvdisp nodes
[0002.084] E> no valid display unit config found in dtb
[0002.087] W> display init failed
[0002.089] I> Load in CBoot Boot Options partition and parse it
[0002.101] E> Error -9 when finding node with path /boot-configuration
[0002.101] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.108] I> Hit any key to stop autoboot:     4       3       2       1
[0004.116] initializing target
[0004.116] calling apps_init()
[0004.117] starting app kernel_boot_app
[0004.136] I> found decompressor handler: lz4-legacy
[0004.137] I> decompressing BMP blob ...
[0004.140] I> Kernel type = Normal
[0004.141] I> Loading kernel-bootctrl from partition
[0004.141] I> Loading partition kernel-bootctrl at 0xa42b0000 from device(0x1)
[0004.148] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.148] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.149] I> ########## SD boot ##########
[0004.153] I> No sdcard
[0004.155] I> -0 params source =
[0004.158] E> Blockdev open: exit error
[0004.161] E> SD boot failed, err: 724238353
[0004.165] I> ########## USB boot ##########
[0004.174] W> No valid slot number is found in scratch register
[0004.175] W> Return default slot: _a
[0004.191] I> USB Firmware Version: 60.06 release
[0004.247] I> enabling 'vdd-5v-sata' regulator
[0004.252] I> regulator of usb2-1 already enabled
[0004.257] I> regulator of usb2-2 already enabled
[0004.261] I> regulator of usb2-3 already enabled
[0005.265] E> failed to initialize xhci controller
[0005.265] E> Error in init of XUSB host driver, err: 79790026
[0005.265] E> Failed to initialize device 5-0
[0005.266] E> USB boot failed, err: 2037973030
[0005.266] I> ########## Fixed storage boot ##########
[0005.266] I> Already published: 00010003
[0005.267] I> Look for boot partition
[0005.270] I> Fallback: assuming 0th partition is boot partition
[0005.276] I> Detect filesystem
[0005.303] I> Loading extlinux.conf ...
[0005.303] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0005.346] I> L4T boot options
[0005.346] I> [1]: "primary kernel"
[0005.347] I> Enter choice:
[0008.348] I> Continuing with default option: 1
[0008.348] I> Loading kernel sig file from rootfs ...
[0008.348] I> rootfs path: /sdmmc_user/boot/Image.sig
[0008.367] I> Loading kernel binary from rootfs ...
[0008.367] I> rootfs path: /sdmmc_user/boot/Image
[0008.608] I> Validate kernel ...
[0008.608] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0008.933] I> No kernel-dtb binary path
[0008.933] W> No valid slot number is found in scratch register
[0008.934] W> Return default slot: _a
[0008.934] I> A/B: bin_type (38) slot 0
[0008.934] I> Loading kernel-dtb from partition
[0008.934] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0008.943] I> Validate kernel-dtb ...
[0008.943] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0008.948] I> Loading ramdisk from rootfs ...
[0008.949] I> rootfs path: /sdmmc_user/boot/initrd
[0009.008] I> Kernel hdr @0xa42b0000
[0009.009] I> Kernel dtb @0x90000000
[0009.009] I> decompressor handler not found
[0009.009] I> Copying kernel image (34799632 bytes) from 0xa42b0000 to 0x80080000 ... e
[0009.016] I> Updated bpmp info to DTB
[0009.018] I> Ramdisk: Base: 0x92000000; Size: 0x54eb56
[0009.018] I> Updated initrd info to DTB
[0009.018] W> WARN: Fail to override "console=none" in commandline
[0009.021] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.029] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.036] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0009.043] W> No valid slot number is found in scratch register
[0009.049] W> Return default slot: _a
[0009.052] I> Active slot suffix:
[0009.055] I> add_boot_slot_suffix: slot_suffix =
[0009.060] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1
[0009.084] I> Updated bootarg info to DTB
[0009.088] W> MAC addr invalid!
[0009.091] E> Failed to get WIFI MAC address
[0009.095] W> MAC addr invalid!
[0009.098] E> Failed to get Bluetooth MAC address
[0009.102] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:e5:79:42
[0009.109] W> "plugin-manager" doesn't exist, creating
[0009.114] I> Adding /chosen/plugin-manager/cvm
[0009.118] W> "chip-id" doesn't exist, creating
[0009.122] I> Adding /chosen/plugin-manager/chip-id
[0009.127] W> "configs" doesn't exist, creating
[0009.131] I> Adding /chosen/plugin-manager/configs
[0009.135] W> "ids" doesn't exist, creating
[0009.139] I> Adding /chosen/plugin-manager/ids
[0009.144] W> "odm-data" doesn't exist, creating
[0009.148] I> Adding /chosen/plugin-manager/odm-data
[0009.156] W> "memory" doesn't exist, creating
[0009.158] I> [0] START: 0x80000000, END: 0xac000000
[0009.162] I> [1] START: 0xac004000, END: 0xf09d0000
[0009.166] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0009.171] I> dram_block larger than 80000000
[0009.175] I> [3] START: 0x100000000, END: 0x480000000
[0009.180] I> added [base:0x80000000, size:0x2c000000] to /memory
[0009.186] I> added [base:0xac200000, size:0x44600000] to /memory
[0009.192] I> added [base:0x100000000, size:0x380000000] to /memory
[0009.199] I> Updated memory info to DTB
[0009.202] E> add_disp_param: failed to get display params for du=0
[0009.208] W> "reset" doesn't exist, creating
[0009.212] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0009.217] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0009.221] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0009.226] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0009.231] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0009.235] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0009.240] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0009.245] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0009.251] W> "misc-data" doesn't exist, creating
[0009.254] I> Boot-device: eMMC
[0009.257] I> Add boot-sdmmc to plugin-manager/misc-data
[0009.262] I> Add storage-sdmmc to plugin-manager/misc-data
[0009.267] W> Unknown storage device
[0009.272] I> Add serial number:0421119068803 as DT property
[0009.277] I> Plugin-manager override starting
[0009.281] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0009.288] I> node /plugin-manager/fragement-soft-wdt matches
[0009.296] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0009.300] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0009.311] I> Disable plugin-manager status in FDT
[0009.312] I> Plugin-manager override finished successfully
[0009.314] I> tegrabl_load_kernel_and_dtb: Done
[0009.318] E> tegrabl_display_clear: display is not initialized
[0009.323] W> Boot logo display failed...
[0009.327] I> Kernel EP: 0x80080000, DTB: 0x90000000
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.140-tegra (root@SWDEV4) (gcc version 7.3.1 20180425 [1
[    0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[    0.000000] OF: fdt:memory scan node memory, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  2c000000
[    0.000000] OF: fdt: - ac200000 ,  44600000
[    0.000000] OF: fdt: - 100000000 ,  380000000
[    0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[    0.000000] bootconsole [tegra_comb_uart0] enabled
��WARNING: pll_d3 has no dyn ramp
thanks
  1. Please be sure that you didn’t put the binary from different jetpack to the same BSP. For example, using rel-32.4.3 kernel over rel-32.6.1 BSP may cause problem…
  2. Please follow official document.
    https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/kernel_custom.html#
  3. Please do change those binary one by one so that you would know which one is causing problem. For example, please do not apply a lots of patch to your kernel and dts files and then flash them both. You won’t be able to know which one causes the crash. Build the vanilla code and update the dtb or kernel first.
  4. Remove “quiet” inside /boot/extlinux/extlinux.conf so that full kernel log will be printed in your uart console.
