max77620.c (22.5 KB)
I’ve added the following differences to get the values on boot-up time
diff --git a/kernel/kernel-4.9/drivers/mfd/max77620.c b/kernel/kernel-4.9/drivers/mfd/max77620.c
index c3daafbbd..6f61e5d5b 100644
--- a/kernel/kernel-4.9/drivers/mfd/max77620.c
+++ b/kernel/kernel-4.9/drivers/mfd/max77620.c
@@ -438,6 +438,12 @@ static int max77620_init_backup_battery_charging(struct max77620_chip *chip)
return ret;
+//BEGIN
+ else {
+ dev_info(dev, "Backup battery charging support enabled\n");
+//END
ret = of_property_read_u32(np,
"backup-battery-charging-current", &pval);
if (ret < 0)
@@ -494,6 +500,10 @@ static int max77620_init_backup_battery_charging(struct max77620_chip *chip)
else if (resistor <= 6000)
config |= 3 << MAX77620_CNFGBBC_RESISTOR_SHIFT;
+//BEGIN
+ dev_info(dev, "Backup battery charging_current:%d, charging_voltage:%d, resistor:%d\n", charging_current, charging_voltage, resistor);
+//END
ret = regmap_write(chip->rmap, MAX77620_REG_CNFGBBC, config);
if (ret < 0) {
dev_err(dev, "Reg 0x%02x write failed, %d\n",
In the dmesg, we’ve got the result from the following line:
[ 0.968703] max77620 4-003c: Backup battery charging_current:100, charging_voltage:3000, resistor:100
And here are the full dmesg logs.
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (ubuntu@ubuntu-desktop) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Oct 28 11:05:59 +03 2022
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 6c4800000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a06b3000
[ 0.000000] Found lut_mem: 00002008@a06b0000
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fbc00000
[ 0.000000] On node 0 totalpages: 7273981
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 521213 pages, LIFO batch:31
[ 0.000000] Normal zone: 105512 pages used for memmap
[ 0.000000] Normal zone: 6752768 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ 0.000000] pcpu-alloc: s57624 r8192 d32488 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 7160277
[ 0.000000] Kernel command line: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06b3000 lut_mem=0x2008@0xa06b0000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 30004(91%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Memory: 27788892K/29095924K available (15358K kernel code, 2958K rwdata, 6732K rodata, 8640K init, 610K bss, 553368K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB)
[ 0.000000] .rodata : 0xffffff8008f80000 - 0xffffff8009620000 ( 6784 KB)
[ 0.000000] .init : 0xffffff8009620000 - 0xffffff8009e90000 ( 8640 KB)
[ 0.000000] .data : 0xffffff8009e90000 - 0xffffff800a173808 ( 2959 KB)
[ 0.000000] .bss : 0xffffff800a173808 - 0xffffff800a20c0b4 ( 611 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf1bc28000 ( 444 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc6f0a00000 ( 28426 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000006] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.008380] Console: colour dummy device 80x25
[ 0.012456] console [tty0] enabled
[ 0.015580] bootconsole [tegra_comb_uart0] disabled
[ 0.020850] kmemleak: Kernel memory leak detector disabled
[ 0.020886] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.020939] pid_max: default: 32768 minimum: 301
[ 0.021996] Security Framework initialized
[ 0.022558] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.022600] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.024627] ftrace: allocating 47116 entries in 185 pages
[ 0.423821] sched-energy: Sched-energy-costs installed from DT
[ 0.423859] ASID allocator initialised with 65536 entries
[ 0.462601] tegra-id: chipid=21917.
[ 0.462628] tegra-id: opt_subrevision=1.
[ 0.462665] Tegra Revision: A02p SKU: 0x99 CPU Process: 0 SoC Process: 0
[ 0.462715] DTS File Name: /home/ubuntu/Desktop/agxi_rtc/forecr_xavier_kernel/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen-industrial/kernel-dts/tegra194-p2888-0008-dsboard-xv2-0000.dts
[ 0.462777] DTB Build time: Oct 28 2022 10:32:54
[ 0.510435] CPU1: Booted secondary processor [4e0f0040]
[ 0.542549] CPU2: Booted secondary processor [4e0f0040]
[ 0.574732] CPU3: Booted secondary processor [4e0f0040]
[ 0.606931] CPU4: Booted secondary processor [4e0f0040]
[ 0.639023] CPU5: Booted secondary processor [4e0f0040]
[ 0.671534] CPU6: Booted secondary processor [4e0f0040]
[ 0.703446] CPU7: Booted secondary processor [4e0f0040]
[ 0.703717] Brought up 8 CPUs
[ 0.703883] SMP: Total of 8 processors activated.
[ 0.703909] CPU features: detected feature: Privileged Access Never
[ 0.703956] CPU features: detected feature: LSE atomic instructions
[ 0.703993] CPU features: detected feature: User Access Override
[ 0.704018] CPU features: detected feature: 32-bit EL0 Support
[ 0.705806] CPU: All CPU(s) started at EL2
[ 0.705893] alternatives: patching kernel code
[ 0.714513] devtmpfs: initialized
[ 0.762224] Initilizing CustomIPI irq domain
[ 0.762488] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.762529] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.772783] pinctrl core: initialized pinctrl subsystem
[ 0.773055] OS set in device tree is not L4T.
[ 0.773361] regulator-dummy: no parameters
[ 0.773637] Initializing plugin-manager
[ 0.773739] Plugin module not found
[ 0.773793] Plugin-manager status disabled
[ 0.775006] NET: Registered protocol family 16
[ 0.776681] pstore: using zlib compression
[ 0.777367] console [pstore-1] enabled
[ 0.777392] pstore: Registered ramoops as persistent store backend
[ 0.777420] ramoops: attached 0x200000@0xffe00000, ecc: 0/0
[ 0.790843] cpuidle: using governor menu
[ 0.792008] bpmp: waiting for handshake
[ 0.792037] bpmp: handshake completed
[ 0.792072] bpmp: synchronizing channels
[ 0.792123] bpmp: channels synchronized
[ 0.792152] bpmp: mail init ok
[ 0.795047] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.795260] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.795289] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.795345] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.795371] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.795397] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.795444] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.795478] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.795534] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.795579] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.795606] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.799118] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e94000)
[ 0.799180] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.801839] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.803141] tegra_aon_clk_init: ok
[ 0.803179] Registering BPMP clocks...
[ 0.803340] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.803973] Serial: AMBA PL011 UART driver
[ 0.804154] tegra_powergate_init: DONE
[ 0.804190] DTS File Name: /home/ubuntu/Desktop/agxi_rtc/forecr_xavier_kernel/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen-industrial/kernel-dts/tegra194-p2888-0008-dsboard-xv2-0000.dts
[ 0.804281] DTB Build time: Oct 28 2022 10:32:54
[ 0.807213] Tegra reboot handler registered.
[ 0.815486] iommu: Adding device 14180000.pcie to group 0
[ 0.816343] iommu: Adding device 14100000.pcie to group 1
[ 0.817098] iommu: Adding device 14140000.pcie to group 2
[ 0.817888] iommu: Adding device 141a0000.pcie to group 3
[ 0.819404] iommu: Adding device 2490000.ether_qos to group 4
[ 0.820087] iommu: Adding device 3100000.serial to group 5
[ 0.820727] iommu: Adding device 3110000.serial to group 6
[ 0.821236] iommu: Adding device 3140000.serial to group 7
[ 0.821913] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.822153] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.822213] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.822271] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.822301] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.822382] tegra-pmc: PMC Prod config success
[ 0.822659] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.822713] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.823103] iommu: Adding device 3460000.sdhci to group 8
[ 0.823731] iommu: Adding device 3400000.sdhci to group 9
[ 0.824330] iommu: Adding device 2450000.ufshci to group 10
[ 0.824889] iommu: Adding device 3210000.spi to group 11
[ 0.825383] iommu: Adding device 3270000.spi to group 12
[ 0.825801] iommu: Adding device 3300000.spi to group 13
[ 0.826855] iommu: Adding device 3160000.i2c to group 14
[ 0.827313] iommu: Adding device c240000.i2c to group 15
[ 0.827761] iommu: Adding device 3180000.i2c to group 16
[ 0.828240] iommu: Adding device 3190000.i2c to group 17
[ 0.828841] iommu: Adding device 31b0000.i2c to group 18
[ 0.829295] iommu: Adding device 31c0000.i2c to group 19
[ 0.829737] iommu: Adding device c250000.i2c to group 20
[ 0.830221] iommu: Adding device 31e0000.i2c to group 21
[ 0.831334] iommu: Adding device 3510000.hda to group 22
[ 0.831774] iommu: Adding device b040000.sce to group 23
[ 0.832408] iommu: Adding device bc00000.rtcpu to group 24
[ 0.834429] iommu: Adding device 13e10000.host1x to group 25
[ 0.834896] iommu: Adding device 13e10000.host1x:ctx0 to group 26
[ 0.835336] iommu: Adding device 13e10000.host1x:ctx1 to group 27
[ 0.835763] iommu: Adding device 13e10000.host1x:ctx2 to group 28
[ 0.836205] iommu: Adding device 13e10000.host1x:ctx3 to group 29
[ 0.836666] iommu: Adding device 13e10000.host1x:ctx4 to group 30
[ 0.837137] iommu: Adding device 13e10000.host1x:ctx5 to group 31
[ 0.837555] iommu: Adding device 13e10000.host1x:ctx6 to group 32
[ 0.838057] iommu: Adding device 13e10000.host1x:ctx7 to group 33
[ 0.838691] iommu: Adding device 15340000.vic to group 34
[ 0.839167] iommu: Adding device 15380000.nvjpg to group 35
[ 0.839522] iommu: Adding device 15500000.tsec to group 36
[ 0.839844] iommu: Adding device 15100000.tsecb to group 37
[ 0.840154] iommu: Adding device 15480000.nvdec to group 38
[ 0.840510] iommu: Adding device 15140000.nvdec1 to group 39
[ 0.840844] iommu: Adding device 154c0000.nvenc to group 40
[ 0.841180] iommu: Adding device 15a80000.nvenc1 to group 41
[ 0.841707] iommu: Adding device 15880000.nvdla0 to group 42
[ 0.842252] iommu: Adding device 158c0000.nvdla1 to group 43
[ 0.842895] iommu: Adding device 15200000.nvdisplay to group 44
[ 0.843142] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06b3000(800000)
[ 0.843186] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06b0000(3000)
[ 0.847133] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.847258] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.849727] iommu: Adding device 15c10000.vi to group 45
[ 0.850001] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.850533] iommu: Adding device 14800000.isp to group 46
[ 0.851609] iommu: Adding device 16000000.pva0 to group 47
[ 0.852303] iommu: Adding device 16800000.pva1 to group 48
[ 0.852793] iommu: Adding device 15810000.se to group 49
[ 0.853343] iommu: Adding device 15820000.se to group 50
[ 0.853654] iommu: Adding device 15830000.se to group 51
[ 0.853952] iommu: Adding device 15840000.se to group 52
[ 0.854291] iommu: Adding device c1a0000.aon to group 53
[ 0.856545] iommu: Adding device d000000.bpmp to group 54
[ 0.856974] bpmp: ping status is 0
[ 0.857134] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[ 0.860564] bpmp d000000.bpmp: probe ok
[ 0.862435] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.862948] iommu: Adding device smmu_test to group 55
[ 0.864338] mc: mapped MMIO address: 0xffffff800a5e0000 -> 0x2c10000
[ 0.864400] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c20000
[ 0.864454] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c30000
[ 0.864521] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2c40000
[ 0.864573] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2c50000
[ 0.864623] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2b80000
[ 0.864678] mc: mapped MMIO address: 0xffffff800b070000 -> 0x2b90000
[ 0.864727] mc: mapped MMIO address: 0xffffff800b090000 -> 0x2ba0000
[ 0.864777] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x2bb0000
[ 0.864829] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1700000
[ 0.864904] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1710000
[ 0.864954] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1720000
[ 0.865021] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1730000
[ 0.865074] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1740000
[ 0.865122] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1750000
[ 0.865174] mc: mapped MMIO address: 0xffffff800b190000 -> 0x1760000
[ 0.865221] mc: mapped MMIO address: 0xffffff800b1b0000 -> 0x1770000
[ 0.865337] mc-err: mcerr ops are set to t19x
[ 0.872802] iommu: Adding device 2600000.dma to group 56
[ 0.878514] gpio gpiochip0: gpio-line-names specifies 210 line names but there are 224 lines on the chip
[ 0.879750] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.880099] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.888418] gpio gpiochip1: gpio-line-names specifies 30 line names but there are 40 lines on the chip
[ 0.888577] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.888884] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.891279] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[ 0.891315] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.891344] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.892058] iommu: Adding device 3550000.xudc to group 57
[ 0.892776] iommu: Adding device 3610000.xhci to group 58
[ 0.894991] arm64_ras arm64_ras: probed
[ 0.895502] ras_fhi_enable: FHI 482 enabled on CPU0
[ 0.895571] ras_fhi_enable: FHI 483 enabled on CPU1
[ 0.895668] ras_fhi_enable: FHI 484 enabled on CPU2
[ 0.895764] ras_fhi_enable: FHI 485 enabled on CPU3
[ 0.895853] ras_fhi_enable: FHI 486 enabled on CPU4
[ 0.895963] ras_fhi_enable: FHI 487 enabled on CPU5
[ 0.896112] ras_fhi_enable: FHI 488 enabled on CPU6
[ 0.896230] ras_fhi_enable: FHI 489 enabled on CPU7
[ 0.896489] carmel_ras_enable: RAS enabled on cpu0
[ 0.896695] carmel_ras_enable: RAS enabled on cpu1
[ 0.896904] carmel_ras_enable: RAS enabled on cpu2
[ 0.897103] carmel_ras_enable: RAS enabled on cpu3
[ 0.897317] carmel_ras_enable: RAS enabled on cpu4
[ 0.897526] carmel_ras_enable: RAS enabled on cpu5
[ 0.897765] carmel_ras_enable: RAS enabled on cpu6
[ 0.897999] carmel_ras_enable: RAS enabled on cpu7
[ 0.898133] carmel_ras carmel_ras: probed
[ 0.899346] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 491, noc_nonsecure_irq = 490>
[ 0.899938] tegra-cbb c600000.aon-noc: noc_secure_irq = 493, noc_nonsecure_irq = 492>
[ 0.900717] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 495, noc_nonsecure_irq = 494>
[ 0.901559] tegra-cbb be00000.rce-noc: noc_secure_irq = 497, noc_nonsecure_irq = 496>
[ 0.902375] tegra-cbb b600000.sce-noc: noc_secure_irq = 499, noc_nonsecure_irq = 498>
[ 0.902780] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.906096] vdd-3v3-cvb: 3300 mV
[ 0.906445] vdd-1v8-cvb: 1800 mV
[ 0.906874] vdd-1v8-sd: 1800 mV
[ 0.907235] vdd-epb-1v0: 1000 mV
[ 0.907497] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.907793] vdd-sdmmc1-sw: 3300 mV
[ 0.908184] avdd-cam-2v8: 2800 mV
[ 0.908550] vdd-sata-1v5: 1500 mV
[ 0.908887] vdd-1v8-slt: 1800 mV
[ 0.909197] vdd-3v3-slt: 3300 mV
[ 0.909578] vdd-fan: 5000 mV
[ 0.909986] vdd-hdmi-5v0: 5000 mV
[ 0.910377] vdd_sys_en: 1200 mV
[ 0.910765] vdd-5v-sata: 5000 mV
[ 0.911226] vdd-3v3-pcie: 3300 mV
[ 0.911727] vdd-12v-pcie: 1200 mV
[ 0.912221] vdd-ac-bat: 5000 mV
[ 0.912455] vdd-5v-sata: supplied by vdd-ac-bat
[ 0.944457] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.948776] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.949114] SCSI subsystem initialized
[ 0.949349] libata version 3.00 loaded.
[ 0.949565] usbcore: registered new interface driver usbfs
[ 0.949656] usbcore: registered new interface driver hub
[ 0.949761] usbcore: registered new device driver usb
[ 0.954328] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (pcf8574a)
[ 0.954379] pcf857x 1-0038: probed
[ 0.962329] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 0.965266] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x2
[ 0.968662] max77620 4-003c: Backup battery charging support enabled
[ 0.971937] vdd-1v0: at 1000 mV
[ 0.975986] vdd-1v8-hs: at 1800 mV
[ 0.980002] vdd-1v8-ls: at 1800 mV
[ 0.984000] vdd-1v8-ao: at 1800 mV
[ 0.988021] vddio-ddr-1v1: at 1100 mV
[ 0.991770] vdd-rtc: at 800 mV
[ 0.993078] spmic-ldo1: at 2375 mV
[ 0.999798] vdd-ao-3v3: at 3300 mV
[ 1.007089] vddio-emmc-3v3: at 3300 mV
[ 1.008408] spmic-ldo4: at 1587 mV
[ 1.015859] vdd-usb-3v3: at 3300 mV
[ 1.023168] vddio-sdmmc1-3v3: at 3300 mV
[ 1.027184] vdd-csi-1v2: at 1200 mV
[ 1.028690] spmic-ldo8: at 1800 mV
[ 1.033640] GPIO line 238 (gpio_default) hogged as output/high
[ 1.035083] GPIO line 239 (gpio_default) hogged as output/high
[ 1.035534] gpiochip_setup_dev: registered GPIOs 232 to 239 on device: gpiochip3 (max77620-gpio)
[ 1.035859] max77620 4-003c: max77620 probe successful
[ 1.036563] media: Linux media interface: v0.10
[ 1.036651] Linux video capture interface: v2.00
[ 1.037977] pps_core: LinuxPPS API ver. 1 registered
[ 1.038007] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.038077] PTP clock support registered
[ 1.038375] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 1.038663] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.038721] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.041487] trusty trusty: trusty version: Built: 02:25:37 Apr 17 2022
[ 1.041590] trusty trusty: selected api version: 3 (requested 3)
[ 1.042575] Advanced Linux Sound Architecture Driver Initialized.
[ 1.043085] Bluetooth: Core ver 2.22
[ 1.043146] NET: Registered protocol family 31
[ 1.043170] Bluetooth: HCI device and connection manager initialized
[ 1.043207] Bluetooth: HCI socket layer initialized
[ 1.043273] Bluetooth: L2CAP socket layer initialized
[ 1.043321] Bluetooth: SCO socket layer initialized
[ 1.045844] camchar: rtcpu character device driver loaded
[ 1.047764] clocksource: Switched to clocksource arch_sys_counter
[ 1.093512] VFS: Disk quotas dquot_6.6.0
[ 1.093681] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.094055] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.095850] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.095948] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 1.096304] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 1.096362] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 1.096403] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.096439] nvmap_page_pool_init: Total RAM pages: 7135639
[ 1.096470] nvmap_page_pool_init: nvmap page pool size: 891954 pages (3484 MB)
[ 1.096790] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.097224] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 1.098720] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.112815] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.113104] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.113397] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.113637] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.113860] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 1.114000] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[ 1.114144] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 1.115379] la/ptsa driver initialized.
[ 1.115753] NET: Registered protocol family 2
[ 1.115945] IP idents hash table entries: 262144 (order: 9, 2097152 bytes)
[ 1.123347] TCP established hash table entries: 262144 (order: 9, 2097152 bytes)
[ 1.124871] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.125483] TCP: Hash tables configured (established 262144 bind 65536)
[ 1.125581] UDP hash table entries: 16384 (order: 7, 524288 bytes)
[ 1.126049] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes)
[ 1.126834] NET: Registered protocol family 1
[ 1.127559] RPC: Registered named UNIX socket transport module.
[ 1.127597] RPC: Registered udp transport module.
[ 1.127627] RPC: Registered tcp transport module.
[ 1.127654] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.127690] PCI: CLS 0 bytes, default 64
[ 1.128030] Trying to unpack rootfs image as initramfs...
[ 1.349249] Freeing initrd memory: 7068K
[ 1.365579] random: fast init done
[ 1.370315] host1x 13e10000.host1x: initialized
[ 1.373192] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.378183] audit: initializing netlink subsys (disabled)
[ 1.378271] audit: type=2000 audit(0.984:1): initialized
[ 1.378964] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 1.388581] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.389810] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.390455] 9p: Installing v9fs 9p2000 file system support
[ 1.395860] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.396040] io scheduler noop registered
[ 1.396282] io scheduler cfq registered (default)
[ 1.399726] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.433695] iommu: Adding device 2993000.adsp to group 59
[ 1.543580] iommu: Adding device aconnect@2a41000:adsp_audio to group 60
[ 1.544576] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.557272] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.557743] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.558385] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.558951] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.561923] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.562186] misc tegra_camera_ctrl: tegra_camera_isomgr_register: some fields not in DT.
[ 1.562231] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=0, vi_iso_bw=3750000, max_bw=3750000
[ 1.565119] tsec 15500000.tsec: initialized
[ 1.566640] tsec 15100000.tsecb: initialized
[ 1.570619] nvdec 15480000.nvdec: initialized
[ 1.573277] nvdec 15140000.nvdec1: initialized
[ 1.579501] falcon 15340000.vic: initialized
[ 1.581365] falcon 15380000.nvjpg: initialized
[ 1.583135] falcon 154c0000.nvenc: initialized
[ 1.585093] falcon 15a80000.nvenc1: initialized
[ 1.588146] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.590617] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.592152] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.593722] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.595184] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.596804] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.598364] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.599935] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.603722] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.609338] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.609762] scare-pigeon 14b00000.isp-thi: initialized
[ 1.619616] pva 16000000.pva0: initialized
[ 1.650586] pva 16800000.pva1: initialized
[ 1.680712] nvdla 15880000.nvdla0: initialized
[ 1.710811] nvdla 158c0000.nvdla1: initialized
[ 1.712791] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.712833] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.712912] tegradccommon 15200000.dc_common: dma mapping done
[ 1.713135] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=84
[ 1.713175] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.713506] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.713572] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.714014] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.714047] tegra_cec 3960000.tegra_cec: probed
[ 1.714473] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
[ 1.714537] generic_infoframe_type: 0x87
[ 1.714641] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.714704] tegradc 15200000.nvdisplay: Display dc.ffffff800bdd0000 registered with id=0
[ 1.719264] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.719309] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 1.719342] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 1.719638] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.719675] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.721195] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.727533] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.728353] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.728400] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.728548] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.728599] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.730138] kfuse 3830000.kfuse: initialized
[ 1.732013] tegradc 15200000.nvdisplay: probed
[ 1.746947] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.749847] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 51, base_baud = 0) is a TEGRA_UART
[ 1.750950] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 52, base_baud = 0) is a TEGRA_UART
[ 1.751729] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 53, base_baud = 0) is a TEGRA_UART
[ 2.726807] tegra_cec 3960000.tegra_cec: Can't find physical addresse.
[ 2.726814] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 4.283963] console [ttyTCU0] enabled
[ 4.284364] [drm] Initialized
[ 4.284732] Console: switching to colour frame buffer device 240x67
[ 4.296893] tegradc 15200000.nvdisplay: fb registered
[ 4.301931] gpio tegra-gpio wake71 for gpio=98(M:2)
[ 4.307526] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.312898] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.313343] brd: module loaded
[ 4.322901] loop: module loaded
[ 4.325083] tegra_profiler: version: 1.145, samples/io: 49/28
[ 4.330830] tegra_profiler: auth: init
[ 4.335269] nct1008_nct72 4-004c: starting parse dt
[ 4.335723] THERMAL EST: found 3 subdevs
[ 4.335729] THERMAL EST num_resources: 0
[ 4.335735] [THERMAL EST subdev 0]
[ 4.335741] [THERMAL EST subdev 1]
[ 4.335745] [THERMAL EST subdev 2]
[ 4.335794] THERMAL EST: Found 2 profiles, default profile is quiet
[ 4.336219] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 4.336222] THERMAL EST: thz register success.
[ 4.336477] THERMAL EST: end of probe, return err: 0
[ 4.337628] ufs_tegra 2450000.ufshci: freq-table-hz property not specified
[ 4.337637] ufs_tegra 2450000.ufshci: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 4.338731] ufs_tegra 2450000.ufshci: wakeup init done, cdirq 464
[ 4.338741] gpio tegra-gpio-aon wake25 for gpio=32(EE:0)
[ 4.343017] Parent Clock set for DC plld3
[ 4.353818] sd: No Scsi addr parsed to reserve index
[ 4.353855] hisi_sas: driver version v1.6
[ 4.361856] qspi_mtd spi6.0: s25fs512s SSG 8 0 1000 4000000
[ 4.361864] qspi_mtd spi6.0: s25fs512s (65536 Kbytes)
[ 4.361872] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x4000000 (64MiB) .erasesize = 0x00040000 (256KiB) .numeraseregions = 0
[ 4.362456] 1 ofpart partitions found on MTD device spi6.0
[ 4.362460] Creating 1 MTD partitions on "spi6.0":
[ 4.362472] 0x000000000000-0x000004000000 : "Whole_flash0"
[ 4.367861] qspi_mtd spi7.0: mx75u25690f (32768 Kbytes)
[ 4.367871] qspi_mtd spi7.0: mtd .name = spi7.0, .size = 0x2000000 (32MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 4.368257] 1 ofpart partitions found on MTD device spi7.0
[ 4.368260] Creating 1 MTD partitions on "spi7.0":
[ 4.368275] 0x000000000000-0x000002000000 : "Secure_ROM"
[ 4.372724] libphy: Fixed MDIO Bus: probed
[ 4.374516] tun: Universal TUN/TAP device driver, 1.6
[ 4.374519] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 4.375282] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.375286] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.375329] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.375331] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.375369] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.375372] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.375408] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[ 4.375410] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ 4.386602] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[ 4.387132] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 55 ae 23
[ 4.387145] Using phyrst_lpmode = 1 from DT
[ 4.387240] libphy: dwc_phy: probed
[ 4.389457] PPP generic driver version 2.4.2
[ 4.389674] PPP BSD Compression module registered
[ 4.389679] PPP Deflate Compression module registered
[ 4.389695] PPP MPPE Compression module registered
[ 4.389699] NET: Registered protocol family 24
[ 4.389755] usbcore: registered new interface driver r8152
[ 4.389820] usbcore: registered new interface driver asix
[ 4.389859] usbcore: registered new interface driver ax88179_178a
[ 4.389900] usbcore: registered new interface driver cdc_ether
[ 4.389928] usbcore: registered new interface driver net1080
[ 4.389957] usbcore: registered new interface driver cdc_subset
[ 4.389985] usbcore: registered new interface driver zaurus
[ 4.390027] usbcore: registered new interface driver cdc_ncm
[ 4.390230] VFIO - User Level meta-driver version: 0.3
[ 4.391339] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.391355] ehci-pci: EHCI PCI platform driver
[ 4.391401] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.391409] ohci-pci: OHCI PCI platform driver
[ 4.391445] ohci-platform: OHCI generic platform driver
[ 4.396429] tegra-xusb 3610000.xhci: No USB port has OTG_CAP
[ 4.398503] tegradc 15200000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 4.399191] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 4.399201] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 4.400190] usbcore: registered new interface driver uas
[ 4.400243] usbcore: registered new interface driver usb-storage
[ 4.400352] usbcore: registered new interface driver usbserial
[ 4.401802] tegra-xusb 3610000.xhci: Firmware timestamp: 2020-09-11 16:55:03 UTC, Version: 60.09 release
[ 4.401845] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 4.401862] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 4.402556] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 4.402596] tegra-xusb 3610000.xhci: irq 477, io mem 0x03610000
[ 4.402834] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.402839] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.402844] usb usb1: Product: xHCI Host Controller
[ 4.402858] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 4.402862] usb usb1: SerialNumber: 3610000.xhci
[ 4.403390] hub 1-0:1.0: USB hub found
[ 4.403434] hub 1-0:1.0: 4 ports detected
[ 4.404038] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 4.404049] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 4.404057] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 4.404304] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.404310] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.404314] usb usb2: Product: xHCI Host Controller
[ 4.404318] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 4.404324] usb usb2: SerialNumber: 3610000.xhci
[ 4.404589] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 4.404622] tegra-xudc-new 3550000.xudc: extcon_get_extcon_dev_by_cable failed -19
[ 4.404877] hub 2-0:1.0: USB hub found
[ 4.405219] hub 2-0:1.0: 4 ports detected
[ 4.405418] mousedev: PS/2 mouse device common for all mice
[ 4.405517] usbcore: registered new interface driver xpad
[ 4.406404] Wake76 for irq=199
[ 4.406407] Wake77 for irq=199
[ 4.406410] Wake78 for irq=199
[ 4.406412] Wake79 for irq=199
[ 4.406414] Wake80 for irq=199
[ 4.406416] Wake81 for irq=199
[ 4.406418] Wake82 for irq=199
[ 4.406480] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 4.406486] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 4.424663] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 4.424668] Extcon AUX2(HDMI) enable
[ 4.508465] usb usb2: usb_suspend_both: status 0
[ 4.538872] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 4.540429] Wake73 for irq=42
[ 4.541709] rtc rtc1: alarm rtc device
[ 4.541725] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 4.541776] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.541880] i2c /dev entries driver
[ 4.543993] pca954x 2-0070: vcc-pullup regulator not found
[ 4.544007] pca954x 2-0070: pca954x_probe: forcing device bus number, start 30.
[ 4.544011] pca954x 2-0070: device detect skipped.
[ 4.544491] i2c i2c-2: Added multiplexed i2c bus 30
[ 4.544880] i2c i2c-2: Added multiplexed i2c bus 31
[ 4.545201] i2c i2c-2: Added multiplexed i2c bus 32
[ 4.545590] i2c i2c-2: Added multiplexed i2c bus 33
[ 4.546030] i2c i2c-2: Added multiplexed i2c bus 34
[ 4.546303] i2c i2c-2: Added multiplexed i2c bus 35
[ 4.547718] GPIO line 224 (tca6408_38_outlow) hogged as output/low
[ 4.548067] GPIO line 225 (tca6408_38_outlow) hogged as output/low
[ 4.548381] GPIO line 226 (tca6408_38_outlow) hogged as output/low
[ 4.548683] GPIO line 227 (tca6408_38_outlow) hogged as output/low
[ 4.548988] GPIO line 228 (tca6408_38_outlow) hogged as output/low
[ 4.549292] GPIO line 229 (tca6408_38_outlow) hogged as output/low
[ 4.549598] GPIO line 230 (tca6408_38_outlow) hogged as output/low
[ 4.549900] GPIO line 231 (tca6408_38_outlow) hogged as output/low
[ 4.550211] gpiochip_setup_dev: registered GPIOs 224 to 231 on device: gpiochip4 (pcf8574a)
[ 4.550218] pcf857x 36-0038: probed
[ 4.550243] i2c i2c-2: Added multiplexed i2c bus 36
[ 4.550557] i2c i2c-2: Added multiplexed i2c bus 37
[ 4.550590] pca954x 2-0070: registered 8 multiplexed busses for I2C switch pca9548
[ 4.551144] imx219 30-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.575163] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 4.575305] imx219 30-0010: imx219_board_setup: error during i2c read probe (-121)
[ 4.575679] imx219 30-0010: board setup failed
[ 4.575816] imx219: probe of 30-0010 failed with error -121
[ 4.576218] imx219 31-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.600137] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 4.600313] imx219 31-0010: imx219_board_setup: error during i2c read probe (-121)
[ 4.600774] imx219 31-0010: board setup failed
[ 4.600862] imx219: probe of 31-0010 failed with error -121
[ 4.601208] imx219 32-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.625272] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 4.625439] imx219 32-0010: imx219_board_setup: error during i2c read probe (-121)
[ 4.625890] imx219 32-0010: board setup failed
[ 4.625983] imx219: probe of 32-0010 failed with error -121
[ 4.626381] imx219 33-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.650404] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 4.650576] imx219 33-0010: imx219_board_setup: error during i2c read probe (-121)
[ 4.650998] imx219 33-0010: board setup failed
[ 4.651059] imx219: probe of 33-0010 failed with error -121
[ 4.651390] imx219 34-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.675380] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 4.675550] imx219 34-0010: imx219_board_setup: error during i2c read probe (-121)
[ 4.676044] imx219 34-0010: board setup failed
[ 4.676139] imx219: probe of 34-0010 failed with error -121
[ 4.677157] max77620-power max20024-power: Event recorder REG_NVERC : 0x80
[ 4.683366] tegra-thermal-throttle bthrot_cdev: cpufreq policy is not ready defer
[ 4.683679] FAN dev name: pwm-fan
[ 4.683727] FAN:gpio request success.
[ 4.683736] FAN: can't find tach_gpio
[ 4.683745] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 4.683803] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 4.684031] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 4.684037] pwm_fan_driver pwm-fan: tach period: 1000
[ 4.684592] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 4.684597] pwm_fan_driver pwm-fan: index 1: pwm=77, rpm=1000, rru=2, rrd=2, state:2
[ 4.684602] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 4.684606] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 4.684611] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 4.684615] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 4.684619] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 4.684624] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 4.684629] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 4.684634] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 4.685365] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 4.686173] device-mapper: uevent: version 1.0.3
[ 4.686597] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 4.707986] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 4.715576] cpuidle: Initializing cpuidle driver
[ 4.727332] sdhci: Secure Digital Host Controller Interface driver
[ 4.727334] sdhci: Copyright(c) Pierre Ossman
[ 4.727336] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.728289] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 4.730373] CMDQ: cmdq_platfm_init successful
[ 4.730820] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 4.732963] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 4.734618] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 259
[ 4.735803] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 4.737758] tegra-se-nvhost 15810000.se: initialized
[ 4.738847] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.739616] tegra-se-nvhost 15820000.se: initialized
[ 4.740683] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.741480] tegra-se-nvhost 15830000.se: initialized
[ 4.741990] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.742711] tegra-se-nvhost 15840000.se: initialized
[ 4.743575] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.744610] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.744772] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.746062] usbcore: registered new interface driver usbhid
[ 4.746064] usbhid: USB HID core driver
[ 4.751377] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 4.752299] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.752677] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.753183] denver_knobs_init:MTS_VERSION:54811859
[ 4.753262] tegra186-safety-ivc b040000.sce: Probing sce safety driver
[ 4.753524] tegra186-safety-ivc b040000.sce: dma address = 0xffef0000
[ 4.753540] tegra186-safety-ivc b040000.sce: cmdresp: RX: 0x0-0x1080 TX: 0x8000-0x9080
[ 4.753546] tegra186-safety-ivc b040000.sce: hb: RX: 0x1400-0x14c0 TX: 0x9400-0x94c0
[ 4.753553] tegra186-safety-ivc b040000.sce: mods: RX: 0x1500-0x1980 TX: 0x9500-0x9980
[ 4.753848] tegra186-safety-ivc b040000.sce: safety: character device 0 registered
[ 4.753950] tegra186-safety-ivc b040000.sce: safety: character device 1 registered
[ 4.754054] tegra186-safety-ivc b040000.sce: safety: character device 2 registered
[ 4.754062] tegra186-safety-ivc b040000.sce: Successfully probed safety ivc driver
[ 4.754150] L1SS : Command = 8
[ 4.754373] tegra19x_actmon d230000.actmon: in actmon_register()...
[ 4.754973] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 4.754977] L1SS : srcID 2 destID 1 cmdID 1 ClassID 1 is_resp=0
[ 4.754983] L1SS : cmd_resp_l1_callback_not_configured: Class(1), Cmd(1), is_resp(0) not implemented
[ 4.755295] t19x_cache tegra-cache: probed
[ 4.761448] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 4.761463] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 4.761974] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 4.762341] Clocks initialized successfully
[ 4.763680] nvpmodel: initialized successfully
[ 4.770627] usb 1-2: New USB device found, idVendor=05e3, idProduct=0610
[ 4.770632] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.770641] trusty-virtio trusty:virtio: initializing
[ 4.770655] usb 1-2: Product: USB2.1 Hub
[ 4.770658] usb 1-2: Manufacturer: GenesysLogic
[ 4.770858] trusty_ipc virtio0: vring0: va(pa) ffffffc6bc36a000(0) qsz 32 notifyid 1
[ 4.770866] trusty_ipc virtio0: vring1: va(pa) ffffffc6bc384000(0) qsz 32 notifyid 2
[ 4.770983] trusty-virtio trusty:virtio: initializing done
[ 4.771206] trusty_ipc virtio0: is online
[ 4.771512] hub 1-2:1.0: USB hub found
[ 4.771785] hub 1-2:1.0: 4 ports detected
[ 4.771798] tegra-hda 3510000.hda: Override SDO lines to 4
[ 4.772132] usbcore: registered new interface driver snd-usb-audio
[ 4.779850] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.791509] input: tegra-hda-galen-t194 HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.791797] input: tegra-hda-galen-t194 HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.792040] input: tegra-hda-galen-t194 HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 4.792220] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 4.792270] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.792315] input: tegra-hda-galen-t194 HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 4.849024] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 4.861332] mmc0: periodic cache flush enabled
[ 4.861351] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 4.861971] mmcblk0: mmc0:0001 G1J38E 59.3 GiB
[ 4.866235] mmcblk0boot0: mmc0:0001 G1J38E partition 1 31.5 MiB
[ 4.866433] mmcblk0boot1: mmc0:0001 G1J38E partition 2 31.5 MiB
[ 4.866678] mmcblk0rpmb: mmc0:0001 G1J38E partition 3 4.00 MiB
[ 4.869232] OPE platform probe
[ 4.869320] OPE platform probe successful
[ 4.870446] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 4.871564] u32 classifier
[ 4.871566] Actions configured
[ 4.871673] Initializing XFRM netlink socket
[ 4.872484] NET: Registered protocol family 10
[ 4.873457] NET: Registered protocol family 17
[ 4.873469] NET: Registered protocol family 15
[ 4.873519] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.873594] Bluetooth: RFCOMM socket layer initialized
[ 4.873605] Bluetooth: RFCOMM ver 1.11
[ 4.873610] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.873614] Bluetooth: HIDP socket layer initialized
[ 4.873630] 9pnet: Installing 9P2000 support
[ 4.873677] Key type dns_resolver registered
[ 4.878741] Registered cp15_barrier emulation handler
[ 4.878757] Registered setend emulation handler
[ 4.880606] registered taskstats version 1
[ 4.880923] tegra-pcie-dw 14180000.pcie: Setting init speed to max speed
[ 4.881693] OF: PCI: host bridge /pcie@14180000 ranges:
[ 4.881709] OF: PCI: IO 0x38100000..0x381fffff -> 0x38100000
[ 4.881716] OF: PCI: MEM 0x1b40000000..0x1bffffffff -> 0x40000000
[ 4.881720] OF: PCI: MEM 0x1800000000..0x1b3fffffff -> 0x1800000000
[ 4.888095] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 4.914957] usb 2-1: New USB device found, idVendor=05e3, idProduct=0626
[ 4.914961] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.914965] usb 2-1: Product: USB3.1 Hub
[ 4.914968] usb 2-1: Manufacturer: GenesysLogic
[ 4.915781] usb 1-2: usb_suspend_both: status 0
[ 4.915850] usb usb1: usb_suspend_both: status 0
[ 4.918081] hub 2-1:1.0: USB hub found
[ 4.918904] hub 2-1:1.0: 4 ports detected
[ 5.079810] usb 2-1: usb_suspend_both: status 0
[ 5.080018] usb usb2: usb_suspend_both: status 0
[ 5.394868] tegra-pcie-dw 14180000.pcie: link is down
[ 5.395072] tegra-pcie-dw 14180000.pcie: PCI host bridge to bus 0000:00
[ 5.395078] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 5.395085] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 5.395089] pci_bus 0000:00: root bus resource [mem 0x1b40000000-0x1bffffffff] (bus address [0x40000000-0xffffffff])
[ 5.395093] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1b3fffffff pref]
[ 5.395140] pci 0000:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 5.395306] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.395519] iommu: Adding device 0000:00:00.0 to group 61
[ 5.395974] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 5.395996] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.396269] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 5.396292] pcie_pme 0000:00:00.0:pcie001: service driver pcie_pme loaded
[ 5.396418] aer 0000:00:00.0:pcie002: service driver aer loaded
[ 5.396571] pcie_pme 0000:00:00.0:pcie001: unloading service driver pcie_pme
[ 5.396650] aer 0000:00:00.0:pcie002: unloading service driver aer
[ 5.396730] pci_bus 0000:01: busn_res: [bus 01-ff] is released
[ 5.396806] iommu: Removing device 0000:00:00.0 from group 61
[ 5.396834] pci_bus 0000:00: busn_res: [bus 00-ff] is released
[ 5.398352] tegra-pcie-dw 14180000.pcie: PCIe link is not up...!
[ 5.398881] tegra-pcie-dw 14100000.pcie: Setting init speed to max speed
[ 5.399624] OF: PCI: host bridge /pcie@14100000 ranges:
[ 5.399638] OF: PCI: IO 0x30100000..0x301fffff -> 0x30100000
[ 5.399645] OF: PCI: MEM 0x1230000000..0x123fffffff -> 0x40000000
[ 5.399650] OF: PCI: MEM 0x1200000000..0x122fffffff -> 0x1200000000
[ 5.444122] FAN rising trip_level:1 cur_temp:56750 trip_temps[2]:63000
[ 5.910041] tegra-pcie-dw 14100000.pcie: link is down
[ 5.910219] tegra-pcie-dw 14100000.pcie: PCI host bridge to bus 0001:00
[ 5.910226] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 5.910233] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 5.910253] pci_bus 0001:00: root bus resource [mem 0x1230000000-0x123fffffff] (bus address [0x40000000-0x4fffffff])
[ 5.910257] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x122fffffff pref]
[ 5.910283] pci 0001:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 5.910440] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.910651] iommu: Adding device 0001:00:00.0 to group 61
[ 5.910985] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 5.911006] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.911219] pcieport 0001:00:00.0: Signaling PME through PCIe PME interrupt
[ 5.911225] pcie_pme 0001:00:00.0:pcie001: service driver pcie_pme loaded
[ 5.911321] aer 0001:00:00.0:pcie002: service driver aer loaded
[ 5.911486] pcie_pme 0001:00:00.0:pcie001: unloading service driver pcie_pme
[ 5.911578] aer 0001:00:00.0:pcie002: unloading service driver aer
[ 5.911648] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[ 5.911792] iommu: Removing device 0001:00:00.0 from group 61
[ 5.911884] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[ 5.913849] tegra-pcie-dw 14100000.pcie: PCIe link is not up...!
[ 5.914425] tegra-pcie-dw 14140000.pcie: Setting init speed to max speed
[ 5.915296] OF: PCI: host bridge /pcie@14140000 ranges:
[ 5.915310] OF: PCI: IO 0x34100000..0x341fffff -> 0x34100000
[ 5.915316] OF: PCI: MEM 0x12b0000000..0x12bfffffff -> 0x40000000
[ 5.915321] OF: PCI: MEM 0x1280000000..0x12afffffff -> 0x1280000000
[ 6.246450] tegradc 15200000.nvdisplay: blank - powerdown
[ 6.246479] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 6.246483] nct1008_nct72 4-004c: success parsing dt
[ 6.246555] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 6.282196] nct1008_nct72 4-004c: LOC shutdown limit 125
[ 6.283214] nct1008_nct72 4-004c: EXT shutdown limit 117
[ 6.283935] extcon-disp-state external-connection:disp-state: cable 48 state 0
[ 6.283938] Extcon AUX2(HDMI) disable
[ 6.306054] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 6.306607] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 6.315848] tegradc 15200000.nvdisplay: unblank
[ 6.316660] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 6.316787] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 6.318387] Parent Clock set for DC plld3
[ 6.320891] nct1008_nct72 4-004c: initial LOC temp: 54000
[ 6.321656] nct1008_nct72 4-004c: initial EXT temp: 67000
[ 6.322702] nct1008_nct72 4-004c: hi_b:-10, lo_b:128
[ 6.323698] tegradc 15200000.nvdisplay: hdmi: tmds rate:65000K prod-setting:prod_c_hdmi_54m_111m
[ 6.323727] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 6.325135] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 6.359928] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 6.359930] Extcon AUX2(HDMI) enable
[ 6.375277] tegradc 15200000.nvdisplay: sync windows ret = 247
[ 6.435493] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 6.435614] tegra-pcie-dw 14140000.pcie: link is down
[ 6.435832] tegra-pcie-dw 14140000.pcie: PCI host bridge to bus 0003:00
[ 6.435839] pci_bus 0003:00: root bus resource [bus 00-ff]
[ 6.435846] pci_bus 0003:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[ 6.435850] pci_bus 0003:00: root bus resource [mem 0x12b0000000-0x12bfffffff] (bus address [0x40000000-0x4fffffff])
[ 6.435854] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12afffffff pref]
[ 6.435882] pci 0003:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 6.436042] pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
[ 6.436284] iommu: Adding device 0003:00:00.0 to group 61
[ 6.436500] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[ 6.436522] pci 0003:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.436724] pcieport 0003:00:00.0: Signaling PME through PCIe PME interrupt
[ 6.436730] pcie_pme 0003:00:00.0:pcie001: service driver pcie_pme loaded
[ 6.436839] aer 0003:00:00.0:pcie002: service driver aer loaded
[ 6.437129] pcie_pme 0003:00:00.0:pcie001: unloading service driver pcie_pme
[ 6.437222] aer 0003:00:00.0:pcie002: unloading service driver aer
[ 6.437309] pci_bus 0003:01: busn_res: [bus 01-ff] is released
[ 6.437392] iommu: Removing device 0003:00:00.0 from group 61
[ 6.437463] pci_bus 0003:00: busn_res: [bus 00-ff] is released
[ 6.439301] tegra-pcie-dw 14140000.pcie: PCIe link is not up...!
[ 6.480551] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 6.533008] Extcon HDMI: HPD enabled
[ 6.536637] tegradc 15200000.nvdisplay: hdmi: plugged
[ 6.541612] tegra-xusb 3610000.xhci: entering ELPG
[ 6.555139] tegra-xusb 3610000.xhci: entering ELPG done
[ 6.600104] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 6.601536] OF: PCI: IO 0x3a100000..0x3a1fffff -> 0x3a100000
[ 6.602944] OF: PCI: MEM 0x1f40000000..0x1fffffffff -> 0x40000000
[ 6.604363] OF: PCI: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 7.120837] tegra-pcie-dw 141a0000.pcie: link is down
[ 7.122457] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 7.123868] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 7.125212] pci_bus 0005:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[ 7.126598] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 7.128025] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 7.129410] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 7.129552] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 7.129768] iommu: Adding device 0005:00:00.0 to group 61
[ 7.131333] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 7.132723] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 7.134315] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 7.135714] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 7.135880] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 7.136148] pcie_pme 0005:00:00.0:pcie001: unloading service driver pcie_pme
[ 7.136222] aer 0005:00:00.0:pcie002: unloading service driver aer
[ 7.136290] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 7.136376] iommu: Removing device 0005:00:00.0 from group 61
[ 7.137809] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 7.139823] tegra-pcie-dw 141a0000.pcie: PCIe link is not up...!
[ 7.154698] tegra-cbb 14040000.cv-noc: noc_secure_irq = 99, noc_nonsecure_irq = 98>
[ 7.160717] tegra194-isp5 14800000.isp: initialized
[ 7.168592] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 7.172741] tegra194-vi5 15c10000.vi: initialized
[ 7.178791] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--6 bound
[ 7.180294] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--5 bound
[ 7.181734] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--4 bound
[ 7.183162] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--3 bound
[ 7.184615] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--2 bound
[ 7.186013] tegra194-vi5 15c10000.vi: ep of_device is not enabled /host1x/vi@15c10000/ports/port@5/endpoint.
[ 7.188501] tegra-thermal-throttle bthrot_cdev: clk:cpu max:2035200000, min:115200000 steps:25
[ 7.243012] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1211250000, min:114750000 steps:11
[ 7.245410] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 7.246858] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 7.248297] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:50 cutoff:0
[ 7.249654] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 7.250963] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 7.257809] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:44 cutoff:1
[ 7.259119] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 7.260407] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 7.267784] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:50 cutoff:0
[ 7.275222] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 7.285323] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 7.295402] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 7.303574] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 7.312541] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 7.321806] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:44 cutoff:1
[ 7.330094] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 7.410194] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 7.411667] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 7.413138] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 7.414550] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 7.416216] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 7.418646] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 7.421298] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (72)
[ 7.422569] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 7.424720] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=4c29076f2400b1aca1797dafeba3d8643d889753
[ 7.426463] Wake83 for irq=211
[ 7.428011] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 7.432906] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 7.438260] input: gpio-keys as /devices/gpio-keys/input/input4
[ 7.478461] tegra_rtc c2a0000.rtc: setting system clock to 2022-10-28 08:28:59 UTC (1666945739)
[ 7.480226] mmcblk mmc0:0001: Card claimed for testing.
[ 7.516703] bpmp: mounted debugfs mirror
[ 7.524064] ALSA device list:
[ 7.525264] #0: tegra-hda-galen-t194 at 0x3518000 irq 71
[ 7.528791] Freeing unused kernel memory: 8640K
[ 7.566779] Root device found: mmcblk0p1
[ 7.569920] Found dev node: /dev/mmcblk0p1
[ 7.601928] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.605996] Rootfs mounted over mmcblk0p1
[ 7.629458] Switching from initrd to actual rootfs
[ 7.755664] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 7.760272] cgroup: cgroup2: unknown option "nsdelegate"
[ 7.768190] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 7.771648] systemd[1]: Detected architecture arm64.
[ 7.787078] systemd[1]: Set hostname to <nvidia-desktop>.
[ 7.864547] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 7.867605] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 8.017729] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.019384] systemd[1]: Reached target Swap.
[ 8.022874] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.027096] systemd[1]: Created slice User and Session Slice.
[ 8.030773] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.032675] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.037237] systemd[1]: Created slice System Slice.
[ 8.040894] systemd[1]: Listening on udev Kernel Socket.
[ 8.087866] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 8.205925] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 8.467175] systemd-journald[2377]: Received request to flush runtime journal from PID 1
[ 9.065784] cpu-throttle-alert cooling device registered.
[ 9.066241] gpu-throttle-alert cooling device registered.
[ 9.066600] aux-throttle-alert cooling device registered.
[ 9.134040] gpio tegra-gpio wake44 for gpio=192(Y:0)
[ 9.385842] random: crng init done
[ 9.387318] random: 7 urandom warning(s) missed due to ratelimiting
[ 11.865654] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.948778] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 11.953177] net eth0: get_configure_l3v4_filter -->
[ 11.953938] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.584341] Bridge firewalling registered
[ 14.613143] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 14.847148] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 14.847889] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 14.920833] Netfilter messages via NETLINK v0.30.
[ 14.923373] ctnetlink v0.93: registering with nfnetlink.
[ 14.951844] L1SS : Done ..but timeout ... wait for register notify
[ 15.045619] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 26.153354] L1SS : srcID 2 destID 1 cmdID 4 ClassID 2 is_resp=0
[ 26.153364] L1SS : cmd_resp_l1_user_rcv_register_notification(56) num_group=1 1028
[ 36.501244] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 37.235339] zram: Added device: zram0
[ 37.236754] zram: Added device: zram1
[ 37.237982] zram: Added device: zram2
[ 37.239685] zram: Added device: zram3
[ 37.245424] zram: Added device: zram4
[ 37.246997] zram: Added device: zram5
[ 37.249631] zram: Added device: zram6
[ 37.252822] zram: Added device: zram7
[ 37.286216] zram0: detected capacity change from 0 to 1827729408
[ 37.328586] Adding 1784888k swap on /dev/zram0. Priority:5 extents:1 across:1784888k SS
[ 37.333966] zram1: detected capacity change from 0 to 1827729408
[ 37.352042] Adding 1784888k swap on /dev/zram1. Priority:5 extents:1 across:1784888k SS
[ 37.357994] zram2: detected capacity change from 0 to 1827729408
[ 37.376151] Adding 1784888k swap on /dev/zram2. Priority:5 extents:1 across:1784888k SS
[ 37.384414] zram3: detected capacity change from 0 to 1827729408
[ 37.401307] Adding 1784888k swap on /dev/zram3. Priority:5 extents:1 across:1784888k SS
[ 37.408907] zram4: detected capacity change from 0 to 1827729408
[ 37.426003] Adding 1784888k swap on /dev/zram4. Priority:5 extents:1 across:1784888k SS
[ 37.435115] zram5: detected capacity change from 0 to 1827729408
[ 37.452546] Adding 1784888k swap on /dev/zram5. Priority:5 extents:1 across:1784888k SS
[ 37.457463] zram6: detected capacity change from 0 to 1827729408
[ 37.473996] Adding 1784888k swap on /dev/zram6. Priority:5 extents:1 across:1784888k SS
[ 37.479927] zram7: detected capacity change from 0 to 1827729408
[ 37.498202] Adding 1784888k swap on /dev/zram7. Priority:5 extents:1 across:1784888k SS
[ 37.924135] FAN rising trip_level:1 cur_temp:57700 trip_temps[2]:63000
[ 38.089193] tegradc 15200000.nvdisplay: unblank
[ 38.091321] L1SS : srcID 2 destID 1 cmdID 9 ClassID 1 is_resp=0
[ 38.091332] L1SS : cmd_resp_l1_user_rcv_FuSa_state_notification FuSa State = 2
[ 38.244081] vdd-1v8-sd: disabling
[ 38.244110] vdd-epb-1v0: disabling
[ 38.244117] avdd-cam-2v8: disabling
[ 38.244125] vdd-sata-1v5: disabling
[ 38.244130] vdd-1v8-slt: disabling
[ 38.244135] vdd-3v3-slt: disabling
[ 38.244140] vdd-fan: disabling
[ 38.244145] vdd_sys_en: disabling
[ 38.244150] vdd-5v-sata: disabling
[ 38.244155] vdd-3v3-pcie: disabling
[ 39.591952] fuse init (API version 7.26)
[ 52.124157] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 52.124183] Bluetooth: BNEP socket layer initialized
If you need more info, please let me know.
