Hi rbrtwtrs,
And for anyone else interested in the fanless custom enclosures please respond with your requirements to sales@iotamy.com as follows ;
enclosure size options are
mini = jetson nano dev kit only, no additional components
medium (as shown) = fits half width Rpi Hats like the PoE, and cameras, etc
large = fits full size Rpi Hats, cameras, additional interface boards, etc
option for Front panel
1 = Blank (machine your own custom layout)
2 = Conduit hole and illuminated power switch hole
3 = Nvidia hole pattern and illuminated power switch hole
4 = Auvidia JN30 hole pattern and illuminated power switch hole
5 = IP67 RJ45 hole and illuminated power switch hole
option for back panel
We found that the best way to enclose cameras is to provide an optical glass window for each camera, circular 20mm aperture, using 25mm x 1mm optical glass disc. Then mount the cameras inside the enclosure so they can see through the window. This protects lens from environmental and handling issues and also maintains IP5x and IP6x ratings.
Please provide number of camera apertures required and which camera modules you intend to use
enclosure IP rating
If you require IP5x or IP6x enclosure rating, we can also incorporate IP67 rated connectors for RJ45, USB, Power. We found that the best solution is to use the PoE Hat and an IP67 RJ45 in the front panel, and an IP67 illuminated switch. To access to Jetson Dev kit connectors just remove front panel.
WiFi Antenna Option
Front panel cut-out for external antenna connectors on front panel. e.g. Desktop Wireless M.2 PC Kit AC8625 (Product Brief: Intel® Dual Band Wireless-AC 8265 Desktop Kit)
enclosure color
1 = polished aluminium
2 = black powder coated
screen printing and branding
If you require custom branding and screen printing please send design files
Quantity
Please advise quantity required.
Custom Assembly Service
We can assemble the entire unit for you based on your requirements. For custom assembly, please specify all the components you would like to incorporate into your enclosure and we will quote on delivering the finished assembled unit.
Please email your requirements to sales@iotamy.com. Once we have all of your options, we will quote on the number of units you require.
Regards, henry
