After spend a several month time design and development, Geekworm design and produce a metal case with power and reset control switch for this popular NVIDIA Jetson Nano Developer Kit. We see that at the current market there is no metal case, just acrylic case for the board. So we design a beautiful metal shell for the Jetson nano.
This is a metal enclosure specially designed for NVIDIA Jetson Nano, support to install power switch and reset switch, and reserve the GPIO hole and the installation space of the fan, and easily assemble it.
And you can find the metal case at the following url:
Geekworm Official site
[url]https://geekworm.com/collections/nvidia/products/geekworm-nvidia-jetson-nano-metal-case-with-power-reset-control-switch[/url]
AMAZON USA
[url]Amazon.com
NewEgg USA
[url]Geekworm NVIDIA Jetson Nano Metal Case with Power & Reset Control Switch for NVIDIA Jetson Nano Developer Kit (No Antenna & No Fan) - Newegg.com
AMAZON Japan
[url]https://www.amazon.co.jp/DP/B07RZL6TTM[/url]
AMAZON Germany
[url]https://www.amazon.de/dp/B07RSVBHW1[/url]
AMAZON United Kingdom
[url]https://www.amazon.co.uk/dp/B07RSVBHW1[/url]
AMAZON France
[url]https://www.amazon.fr/dp/B07RSVBHW1[/url]
AMAZON Italy
[url]http://www.amazon.it/dp/B07RSVBHW1[/url]
AMAZON Spain
[url]https://www.amazon.es/dp/B07RSVBHW1[/url]
We do not prepare a cooling fan in the case, as we have tested so many fans, but won’m meet the demand, if you need a cooling fan, you can refer to official recommend Noctua NF-A4x20 5V PWM fan. (We test this fan it is ok to use and a good choice.)
Also you can install an antenna on the case, but you need to buy an antenna yourself if you need to use it.
How do you like this metal case for Jetson Nano?
We update this metal case now, so we added 2 antenna holes to install the antenna and raspberry pi official camera (this camera is recommend by NVIDIA), The diameter of the hole is 7.3mm; Raspberry pi official camera can be insert into the antenna hole.
