021-10-19 00:47:34 [5,438ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/utils/PrefixScanBuffer.compute.hlsl’.
2021-10-19 00:47:34 [5,438ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/utils/PrefixScanBuffer.compute.hlsl
2021-10-19 00:47:34 [5,438ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/e38ecc9ba2a3e1ef21bdaeeb3a3fbf14.d.desc’ does not exist
2021-10-19 00:47:34 [5,438ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2021-10-19 00:47:34 [5,438ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/798980ef1893a5ef3f00bff6b109bb11.d.desc’ does not exist
2021-10-19 00:47:34 [5,438ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/b9531c35fb9569c533f63279652f100a.d.desc’ does not exist
2021-10-19 00:47:34 [5,439ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/scenedb/SparseMemCopy.compute.hlsl’.
2021-10-19 00:47:34 [5,439ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/SparseMemCopy.compute.hlsl
2021-10-19 00:47:34 [5,439ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/1eac9d3b46c084824c86c70ca658b287.d.desc’ does not exist
2021-10-19 00:47:34 [5,439ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2021-10-19 00:47:34 [5,439ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/a04c731d9f35216894dd51f47da9972d.d.desc’ does not exist
2021-10-19 00:47:34 [5,440ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/a0bff707ad65184fc9a72da605c9e3e0.d.desc’ does not exist
2021-10-19 00:47:34 [5,440ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/aff1b6706c1d9b15e4442dca4f51c21d.d.desc’ does not exist
2021-10-19 00:47:34 [5,440ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/utils/PrefixScanTexture.compute.hlsl’.
2021-10-19 00:47:34 [5,440ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/utils/PrefixScanTexture.compute.hlsl
2021-10-19 00:47:34 [5,440ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/2b41ca742d244328ed6fe3cf4d0e2c8e.d.desc’ does not exist
2021-10-19 00:47:34 [5,440ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2021-10-19 00:47:34 [5,441ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/utils/PrefixScanTexture.compute.hlsl
2021-10-19 00:47:34 [5,441ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2021-10-19 00:47:34 [5,441ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/e20afc64433f1fa71a7e1774ab051527.d.desc’ does not exist
2021-10-19 00:47:34 [5,441ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/d0f56772391430f3d9bd98a06c1bb98d.d.desc’ does not exist
2021-10-19 00:47:34 [5,442ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/4fa9bc17d8b82179a84f9c447974d7ca.d.desc’ does not exist
2021-10-19 00:47:34 [5,442ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl’.
2021-10-19 00:47:34 [5,442ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl
2021-10-19 00:47:34 [5,442ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2021-10-19 00:47:34 [5,442ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/b4c02690c7b9666c4babb0373b7f674c.d.desc’ does not exist
2021-10-19 00:47:34 [5,443ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/b96147569e63aeec943f367180d0f65f.d.desc’ does not exist
2021-10-19 00:47:34 [5,443ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl’.
2021-10-19 00:47:34 [5,443ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/lighting/EnvironmentPreprocessingLatLongConversion.compute.hlsl’.
2021-10-19 00:47:34 [5,443ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/77897c927ff3334748543be91ea357e2.d.desc’ does not exist
2021-10-19 00:47:34 [5,443ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl
2021-10-19 00:47:34 [5,443ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingLatLongConversion.compute.hlsl
2021-10-19 00:47:34 [5,443ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2021-10-19 00:47:34 [5,444ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/lighting/EnvironmentPreprocessingLatLongConversion.compute.hlsl’.
2021-10-19 00:47:34 [5,444ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/utils/PrefixScanTexture.compute.hlsl’.
2021-10-19 00:47:34 [5,444ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/utils/PrefixScanBuffer.compute.hlsl’.
2021-10-19 00:47:34 [5,444ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingLatLongConversion.compute.hlsl
2021-10-19 00:47:34 [5,444ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/utils/PrefixScanTexture.compute.hlsl
2021-10-19 00:47:34 [5,444ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/utils/PrefixScanBuffer.compute.hlsl
2021-10-19 00:47:34 [5,444ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2021-10-19 00:47:34 [5,444ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl’.
2021-10-19 00:47:34 [5,444ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl
2021-10-19 00:47:34 [5,444ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/scenedb/TranslateInstancePosition.compute.hlsl’.
2021-10-19 00:47:34 [5,444ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/de84912158c5ece4f0440b8ce9bce625.d.desc’ does not exist
2021-10-19 00:47:34 [5,445ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2021-10-19 00:47:34 [5,445ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/TranslateInstancePosition.compute.hlsl
2021-10-19 00:47:34 [5,445ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl’.
2021-10-19 00:47:34 [5,445ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/75207bb8f23802a0b225d6ff4fd4dc90.d.desc’ does not exist
2021-10-19 00:47:34 [5,445ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/756c1c07a2c79dcf0751b927d6c51353.d.desc’ does not exist
2021-10-19 00:47:34 [5,445ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/lighting/EnvironmentPreprocessingLatLongConversion.compute.hlsl’.
2021-10-19 00:47:34 [5,445ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl
2021-10-19 00:47:34 [5,445ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingLatLongConversion.compute.hlsl
2021-10-19 00:47:34 [5,446ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl
2021-10-19 00:47:34 [5,446ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/d436e5ad2c830364f5dca3f83d9ecb0b.d.desc’ does not exist
2021-10-19 00:47:34 [5,446ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2021-10-19 00:47:34 [5,446ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl’.
2021-10-19 00:47:34 [5,447ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2021-10-19 00:47:34 [5,605ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/743a9acabe8080fe1cce53e8b5095550.d.desc’ does not exist
2021-10-19 00:47:34 [5,605ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/scenedb/Skinning.comp.hlsl’.
2021-10-19 00:47:34 [5,606ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/a765b953e7c7e0d170a77348808160f5.d.desc’ does not exist
2021-10-19 00:47:34 [5,606ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/Skinning.comp.hlsl
2021-10-19 00:47:34 [5,606ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/scenedb/SkinNormal.comp.hlsl’.
2021-10-19 00:47:34 [5,606ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2021-10-19 00:47:34 [5,606ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/SkinNormal.comp.hlsl
2021-10-19 00:47:34 [5,607ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/1b3c69faafe968567d100a4dd8636ce6.d.desc’ does not exist
2021-10-19 00:47:34 [5,607ms] [Info] [carb] Initializing plugin: rtx.rasterizing.plugin (interfaces: [rtx::rasterizing::GBuffer v0.1],[rtx::rasterizing::Primitive v0.1],[rtx::rasterizing::Selection v0.1]) (impl: rtx.rasterizing.plugin)
2021-10-19 00:47:34 [5,607ms] [Info] [carb] Initializing plugin: rtx.neuraylib.plugin (interfaces: [rtx::neuray::NeurayLib v0.2]) (impl: rtx.neuraylib.plugin)
2021-10-19 00:47:34 [5,608ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/dd19e3f4113abe4b510d2387e662ce94.d.desc’ does not exist
2021-10-19 00:47:34 [5,608ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/raytracing/LightVoxels.cs.hlsl’.
2021-10-19 00:47:34 [5,608ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/raytracing/LightVoxels.cs.hlsl
2021-10-19 00:47:34 [5,608ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2021-10-19 00:47:34 [5,608ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/87d7d4169afac536cb0aef804b78d5ab.d.desc’ does not exist
2021-10-19 00:47:34 [5,609ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/0873620e862d540a44c328f8e5eb74ee.d.desc’ does not exist
2021-10-19 00:47:34 [5,609ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/scenedb/NormalGeneration.comp.hlsl’.
2021-10-19 00:47:34 [5,609ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/NormalGeneration.comp.hlsl
2021-10-19 00:47:34 [5,609ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2021-10-19 00:47:34 [5,609ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/05968447abaf2ea3a9d96613fba95955.d.desc’ does not exist
2021-10-19 00:47:34 [5,610ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/ac9df0e3e900c09d788a56881cf7587f.d.desc’ does not exist
2021-10-19 00:47:34 [5,610ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/7f80fdc228012901479e03fb2d6bc2f8.d.desc’ does not exist
2021-10-19 00:47:34 [5,610ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/fb83695e41042dff6aec17bfba69a5e6.d.desc’ does not exist
2021-10-19 00:47:34 [5,610ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/rasterizing/Line.geometry.hlsl’.
2021-10-19 00:47:34 [5,610ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/rasterizing/Line.geometry.hlsl
2021-10-19 00:47:34 [5,610ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/rasterizing/Point.geometry.hlsl’.
2021-10-19 00:47:34 [5,610ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/rasterizing/Point.geometry.hlsl
2021-10-19 00:47:34 [5,610ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/raytracing/SimpleMiss.ms.hlsl’.
2021-10-19 00:47:34 [5,610ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/raytracing/SimpleMiss.ms.hlsl
2021-10-19 00:47:34 [5,611ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/rasterizing/Line.geometry.hlsl
2021-10-19 00:47:34 [5,611ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/1d3728fe54695bbf3b93cd816e043939.d.desc’ does not exist
2021-10-19 00:47:34 [5,611ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/f098193a9c2e2c50ff62b92dd02caa51.d.desc’ does not exist
2021-10-19 00:47:34 [5,611ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/dff5b236c98308bbac9d426507df0501.d.desc’ does not exist
2021-10-19 00:47:34 [5,611ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/49687ab6a76ee40a8e286503f7da984f.d.desc’ does not exist
2021-10-19 00:47:34 [5,611ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/rasterizing/Point.pixel.hlsl’.
2021-10-19 00:47:34 [5,611ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/scenedb/NormalGeneration.comp.hlsl’.
2021-10-19 00:47:34 [5,611ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/rasterizing/Point.geometry.hlsl’.
2021-10-19 00:47:34 [5,611ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/rasterizing/Line.vertex.hlsl’.
2021-10-19 00:47:34 [5,611ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/rasterizing/Point.pixel.hlsl
2021-10-19 00:47:34 [5,611ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/rasterizing/Line.vertex.hlsl
2021-10-19 00:47:34 [5,611ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/rasterizing/Line.pixel.hlsl’.
2021-10-19 00:47:34 [5,611ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/rasterizing/Point.geometry.hlsl
2021-10-19 00:47:34 [5,611ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/NormalGeneration.comp.hlsl
2021-10-19 00:47:34 [5,611ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/rasterizing/Line.pixel.hlsl
2021-10-19 00:47:34 [5,611ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/rasterizing/Line.geometry.hlsl’.
2021-10-19 00:47:34 [5,611ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2021-10-19 00:47:34 [5,622ms] [Info] [rtx.neuraylib.plugin] [API:DATABASE] 0.0 API db info : Loaded “c:\users\gym89\appdata\local\ov\pkg\audio2face-2021.3.1\kit\libs\iray\libneuray.dll”
2021-10-19 00:47:34 [5,622ms] [Info] [rtx.neuraylib.plugin] [API:MISC] 0.0 API misc info : Iray RTX 2021.0.1, build 344800.3563, 21 Jul 2021, nt-x86-64
2021-10-19 00:47:34 [6,003ms] [Info] [carb] Initializing plugin: rtx.materialdb.plugin (interfaces: [rtx::materialdb::MaterialDb v0.7]) (impl: rtx.materialdb.plugin)
2021-10-19 00:47:34 [6,005ms] [Info] [carb] Initializing plugin: rtx.mdltranslator.plugin (interfaces: [rtx::mdltranslator::MdlTranslator v1.0]) (impl: rtx.mdltranslator.plugin)
2021-10-19 00:47:34 [6,008ms] [Info] [carb] file ‘C:/Users/GYM89/AppData/Local/ov/cache/Kit/102.1/834a7871/shadercache/release/0d093d3b28b55d98277af1e52dcdc45d.d.desc’ does not exist
2021-10-19 00:47:34 [6,008ms] [Error] [gpu.foundation.plugin] Cannot load shader file ‘rtx/system/GenerateMipMap.comp.hlsl’.
2021-10-19 00:47:34 [6,008ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/system/GenerateMipMap.comp.hlsl
2021-10-19 00:47:34 [6,008ms] [Error] [gpu.foundation.plugin] Failed to async compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2021-10-19 00:47:34 [6,009ms] [Info] [carb] Initializing plugin: carb.blockcompression.plugin (interfaces: [carb::blockcompression::BlockCompression v0.1]) (impl: carb.blockcompression.plugin)
2021-10-19 00:47:34 [6,038ms] [Error] [gpu.foundation.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2021-10-19 00:47:34 [6,039ms] [Error] [gpu.foundation.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2021-10-19 00:47:34 [6,040ms] [Error] [gpu.foundation.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2021-10-19 00:47:34 [6,041ms] [Error] [gpu.foundation.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2021-10-19 00:47:34 [6,042ms] [Error] [gpu.foundation.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2021-10-19 00:47:34 [6,043ms] [Error] [gpu.foundation.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2021-10-19 00:47:34 [6,044ms] [Error] [gpu.foundation.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2021-10-19 00:47:34 [6,045ms] [Error] [gpu.foundation.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2021-10-19 00:47:34 [6,046ms] [Error] [gpu.foundation.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2021-10-19 00:47:34 [6,047ms] [Error] [gpu.foundation.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
My windows version is : 10.0.19042 build 19042
Nvidia Driver :471.68
