cgjd18
March 25, 2022, 5:41am
#1
Hi there,
I’ve been trying to use A2F 2021.3.3, but the viewport doesn’t come up, and here is a log sheet that shows the errors.
2021.3.3 Errors.txt (363.4 KB)
At the same time A2F 2021.3.0 works as it should with no errors and does everything I want it to (A2F is fantastic).
The other error that comes up is trying to import the .USD file into 3ds Max, this error comes up:
I use the RTX 3060 for development and the 6700xt for gaming. And I make sure the 3060 is activated with the monitor only.
Hopefully, you will have an idea of why this happens.
Thank you for your time!
cgjd18
March 27, 2022, 4:04am
#2
I’m guessing no dice for this one?
cgjd18
March 28, 2022, 2:39am
#3
Solved: Disabling my second GPU in the driver’s manager.
Hello @cgjd18 ! I wanted to let you know that I informed our QA to dig into this issue. Thank you for bringing this to our attention!
Hello @cgjd18 ! The development team is working on a solution to this issue and has asked me to get a bit more information from you. Could you please let me know your Operating System and the GPU Driver you are using?
Operating System: ?
GPU(s): RTX 3060 & 6700 XT
GPU Driver: ?
Hi @WendyGram , sure thing.
OS: Windows 10 Version 10.0.19043 Build 19043
GPUs:
Nvidia RTX 3060, Driver Version: 30.0.15.1215
AMD 6700XT, Driver Version: 30.0.15021.1001
Let me know what other info you may need.
