After update, upgrade and installing correct headers, ive installed nvidia driver and nvidia-cuda-toolkit. During instalation i had message that default gpu drivers will be disabled after reboot.
After reboot i got blinking lop-left cursor and then BLACK SCREEN appears. Cant do anything.
Ive entered recovery mode and there everything works fine. Gui is enabled and drivers are installed fine.
lspci -s 29:00.0 -v
29:00.0 VGA compatible controller: NVIDIA Corporation GA104 [GeForce RTX 3070] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. [MSI] GA104 [GeForce RTX 3070]
Flags: bus master, fast devsel, latency 0, IRQ 94, IOMMU group 16
Memory at fb000000 (32-bit, non-prefetchable) [size=16M]
Memory at 7fe0000000 (64-bit, prefetchable) [size=256M]
Memory at 7ff0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at fc000000 [virtual] [disabled] [size=512K]
Capabilities: <access denied>
Kernel driver in use: nvidia
Kernel modules: nvidia
nvidia-smi
Thu Feb 29 21:03:06 2024
| NVIDIA-SMI 525.147.05 Driver Version: 525.147.05 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:29:00.0 On | N/A |
| 0% 39C P3 35W / 280W | 1051MiB / 8192MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1016 G /usr/lib/xorg/Xorg 897MiB |
| 0 N/A N/A 1288 G xfwm4 4MiB |
| 0 N/A N/A 1864 G ...b/firefox-esr/firefox-esr 146MiB |
I tried to delete xorg.conf like many tutorials said, but that file is missing.
[/etc/X11]
└─$ ls
Xreset Xresources Xsession.d XvMCConfig app-defaults fonts xinit xorg.conf.d
Xreset.d Xsession Xsession.options Xwrapper.config default-display-manager rgb.txt xkb xsm
nvidia-bug-report.log (1.3 MB)
