Black Screen on GeForce GTX 1050 Ti Mobile with nvidia-driver-470
I think I have found the solution for my specific problem. It is an xorg-server ubuntu package bug.
Reading my last nvidia-bug-report, I was able to find this:
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (II) Module fb: vendor="X.Org Foundation"
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]:         compiled for 1.20.11, module version = 1.0.0
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]:         ABI class: X.Org ANSI C Emulation, version 0.4
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: Xorg: ../../../../dix/privates.c:384: dixRegisterPrivateKey: Assertion `!global_keys[type].created' failed.
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE)
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) Backtrace:
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 0: /usr/lib/xorg/Xorg (OsLookupColor+0x13c) [0x558b821b660c]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 1: /lib/x86_64-linux-gnu/libpthread.so.0 (funlockfile+0x60) [0x7faf6b6603c0]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 2: /lib/x86_64-linux-gnu/libc.so.6 (gsignal+0xcb) [0x7faf6b49d18b]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 3: /lib/x86_64-linux-gnu/libc.so.6 (abort+0x12b) [0x7faf6b47c859]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) unw_get_proc_name failed: no unwind info found [-10]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 4: /lib/x86_64-linux-gnu/libc.so.6 (?+0x0) [0x7faf6b47c729]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 5: /lib/x86_64-linux-gnu/libc.so.6 (__assert_fail+0x46) [0x7faf6b48df36]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 6: /usr/lib/xorg/Xorg (dixRegisterPrivateKey+0x239) [0x558b82073a99]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 7: /usr/lib/xorg/modules/libglamoregl.so (glamor_init+0xcf) [0x7fa96654237f]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 8: /usr/lib/xorg/modules/drivers/modesetting_drv.so (?+0x0) [0x7fa966580d0d]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 9: /usr/lib/xorg/modules/drivers/modesetting_drv.so (?+0x0) [0x7fa966578fd6]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 10: /usr/lib/xorg/Xorg (AddGPUScreen+0xf5) [0x558b82055315]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 11: /usr/lib/xorg/Xorg (xf86PlatformMatchDriver+0xa44) [0x558b820b03d4]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 12: /usr/lib/xorg/Xorg (xf86PlatformDeviceCheckBusID+0x225) [0x558b820b5e15]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 13: /usr/lib/xorg/Xorg (config_fini+0xa4a) [0x558b820b201a]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 14: /usr/lib/xorg/Xorg (config_fini+0x15eb) [0x558b820b2bbb]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 15: /usr/lib/xorg/Xorg (config_init+0xd) [0x558b820b15ad]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 16: /usr/lib/xorg/Xorg (InitInput+0xb9) [0x558b82094c59]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 17: /usr/lib/xorg/Xorg (InitFonts+0x36d) [0x558b82058f7d]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 18: /lib/x86_64-linux-gnu/libc.so.6 (__libc_start_main+0xf3) [0x7faf6b47e0b3]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) 19: /usr/lib/xorg/Xorg (_start+0x2e) [0x558b82042a6e]
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: Fatal server error:
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) Caught signal 6 (Aborted). Server aborting
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: Please consult the The X.Org Foundation support
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]:          at http://wiki.x.org
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]:  for help.
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
set 15 13:22:11 mymachinename /usr/lib/gdm3/gdm-x-session[961]: (EE) Server terminated with error (1). Closing log file.
set 15 13:22:33 mymachinename /usr/lib/gdm3/gdm-x-session[1324]: (--) Log file renamed from "/var/log/Xorg.pid-1324.log" to "/var/log/Xorg.0.log"
Then searching the web for this global_keys creation failure I was able to find the solution in this xorg-server bug.
The problem listed there is exactly the same I was facing and the solution was listed by PJSingh5000 (pjsingh5000) in the previous link. I will copy it here if someone else looking for a solution find this post:
  1. Edit the file /lib/udev/rules.d/61-gdm.rules.
sudo vim /lib/udev/rules.d/61-gdm.rules
The original file looks like this:
# disable Wayland on Hi1710 chipsets
 ATTR{vendor}=="0x19e5", ATTR{device}=="0x1711", RUN+="/usr/lib/gdm3/gdm-disable-wayland"
 # disable Wayland when using the proprietary nvidia driver
 DRIVER=="nvidia", RUN+="/usr/lib/gdm3/gdm-disable-wayland"
Comment all of the lines as shown:
# ATTR{vendor}=="0x19e5", ATTR{device}=="0x1711", RUN+="/usr/lib/gdm3/gdm-disable-wayland"
# DRIVER=="nvidia", RUN+="/usr/lib/gdm3/gdm-disable-wayland"
Save the file and exit :wq!
  1. Ensure that the Wayland is not disabled in GDM.
sudo vim /etc/gdm3/custom.conf
Comment the “WaylandEnable” line, if it is not already commented, as shown:
# WaylandEnable=false
If changed save the file. Exit vim.
  1. Finally, reboot.
It seems to have solved the problem in my machine but I will keep testing it for a few more days to be sure.
Explanation by PJSingh5000 (pjsingh5000) in the link above
The /lib/udev/rules.d/61-gdm.rules file is supposed to prevent GDM from displaying the Wayland session option when the NVIDIA proprietary drivers are installed, since NVIDIA does not support Wayland.
However, in Ubuntu 20.04, there seems to be another redundant mechanism or rule that also prevents GDM from displaying the Wayland session option. I suspect this, because even after making the above change, the Wayland session option is still not displayed in GDM. (Setting WaylandEnable=true in /etc/gdm3/custom.conf has no effect).
Therefore, I have a hunch that there are two conflicting rules, and disabling one of the rules (i.e. /lib/udev/rules.d/61-gdm.rules) seems to remove the conflict.
