Hi, I saw a module bluedroid_pm with lsmod, anyone knows what is this for ? can I turn it off permanently (blacklist) without breaking the board ?
Hi wenbin.leong,
May I ask why you want to disable it?
for some reason the m2.key socket for Ampak wifi module is not compatible, where WL_REG_ON(pin 23) and BT_REG_ON(42) is missing from Xavier so we need to hack it.
bluedroid_pm stands for “Bluetooth Bluedroid power management Driver.”
If this driver affects your case in other bluetooth device, then please disable it.
Hi @WayneWWW
I am designing my own carrier for Xavier, I also want to disable bluedroid_pm. I have commented out the bluedroid_pm node in device-tree. But how should I set the (GPIO) PIN states for reset, host-wake, and ext-wake in pinmux table?
- reset-gpio connects to W_DISABLE2# (pin 54) of M.2 E. I think it is for enabling BT function of wireless chip on that M.2 E, correct? So, I should set pinmux in GPIO output “drive 1” state, correct?
- ext-wake connects to VENDOR_DEFINED (pin 38) of M.2 E. Is it for Xavier to wake the wireless chip? Should I set pinmux in GPIO output “drive 1” state? Note that the current Xavier devkit pinmux table already sets it to output “drive 1” state.
- host-wake connects to UART_WAKE# (pin 20) of M.2 E. Is it for wireless chip to wake Xavier from deep sleep mode? Should I set pinmux in GPIO input with Pull-up state?
- Are most of M.2 E wireless chips compatible with this pin setting on M.2 E? Especially, for ext-wake where it is connected to VENDOR_DEFINED pin on M.2 E, which seems has high chance of vendor dependency.
- I briefly went thru
kernel/nvidia/drivers/misc/bluedroid_pm.cdriver. Is it in standard upstream linux kernel? Or it is something specific in L4T kernel? I couldn’t find the bluedroid_pm driver in upstream kernel. I even couldn’t find the device-tree binding.
Regards.
Please file a new topic for your issue.
