My system can boot but with many errors in dmesg.
It was happening with the driver 460 on Ubuntu 20.10 and after the update to 21.04. It is still happening now with the driver 465.
NVIDIA Quadro RTX 3000 with Max-Q Design
From dmesg:
[ 6.122747] nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
[ 6.124549] ucsi_ccg 0-0008: i2c_transfer failed -110
[ 6.126450] ucsi_ccg 0-0008: ucsi_ccg_init failed - -110
[ 6.128155] ucsi_ccg: probe of 0-0008 failed with error -110
Overview:
sudo dmesg | grep -Ei "Error|Warning"
[ 0.805440] i8042: Warning: Keylock active
[ 0.895538] RAS: Correctable Errors collector initialized.
[ 1.603746] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20201113/nsarguments-61)
[ 1.821442] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.PEG0.PEGP.GPS.PCGP], AE_NOT_FOUND (20201113/psargs-330)
[ 1.821467] ACPI Error: Aborting method \_SB.PCI0.PEG0.PEGP.GPS due to previous error (AE_NOT_FOUND) (20201113/psparse-529)
[ 1.821471] ACPI Error: Aborting method \_SB.PCI0.PEG0.PEGP._DSM due to previous error (AE_NOT_FOUND) (20201113/psparse-529)
[ 1.821539] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.PEG0.PEGP.GPS.PCGP], AE_NOT_FOUND (20201113/psargs-330)
[ 1.821559] ACPI Error: Aborting method \_SB.PCI0.PEG0.PEGP.GPS due to previous error (AE_NOT_FOUND) (20201113/psparse-529)
[ 1.821563] ACPI Error: Aborting method \_SB.PCI0.PEG0.PEGP._DSM due to previous error (AE_NOT_FOUND) (20201113/psparse-529)
[ 2.020442] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.PEG0.PEGP.GPS.PCGP], AE_NOT_FOUND (20201113/psargs-330)
[ 2.020466] ACPI Error: Aborting method \_SB.PCI0.PEG0.PEGP.GPS due to previous error (AE_NOT_FOUND) (20201113/psparse-529)
[ 2.020470] ACPI Error: Aborting method \_SB.PCI0.PEG0.PEGP._DSM due to previous error (AE_NOT_FOUND) (20201113/psparse-529)
[ 5.149021] dell_wmi_sysman: Error: Expected ACPI-package type, got: 1
[ 5.217647] dell_wmi_sysman: Error: Expected ACPI-package type, got: 1
[ 25.281982] WARNING: CPU: 1 PID: 6036 at /var/lib/dkms/nvidia/465.27/build/nvidia-drm/nvidia-drm-drv.c:568 nv_drm_master_set+0x27/0x30 [nvidia_drm]
[ 25.282398] WARNING: CPU: 1 PID: 6036 at /var/lib/dkms/nvidia/465.27/build/nvidia-drm/nvidia-drm-drv.c:568 nv_drm_master_set+0x27/0x30 [nvidia_drm]
[ 25.282741] WARNING: CPU: 1 PID: 6036 at /var/lib/dkms/nvidia/465.27/build/nvidia-drm/nvidia-drm-drv.c:568 nv_drm_master_set+0x27/0x30 [nvidia_drm]
[ 25.310437] WARNING: CPU: 6 PID: 6322 at /var/lib/dkms/nvidia/465.27/build/nvidia-drm/nvidia-drm-drv.c:568 nv_drm_master_set+0x27/0x30 [nvidia_drm]
[ 25.310726] WARNING: CPU: 6 PID: 6322 at /var/lib/dkms/nvidia/465.27/build/nvidia-drm/nvidia-drm-drv.c:568 nv_drm_master_set+0x27/0x30 [nvidia_drm]
[ 25.310958] WARNING: CPU: 6 PID: 6322 at /var/lib/dkms/nvidia/465.27/build/nvidia-drm/nvidia-drm-drv.c:568 nv_drm_master_set+0x27/0x30 [nvidia_drm]
PS: How can I attach the nvidia-bug-report.log.gz
