Boot fail after reboot
We have an IGX Orin board kit without RTX A6000 which install IGX-SW 1.0 Production Release and update all firmware.
Machine run a few months. Today, reboot the machine and can't boot anymore.
Check the problem by login into BMC and the log show up
“ASSERT [FvbNorFlashStandaloneMm] /out/nvidia/optee.t234-uefi/StandaloneMmOptee_RELEASE/edk2-nvidia/Silicon/NVIDIA/Drivers/FvbNorFlashDxe/FvbNorFlashStandaloneMm.c(937): ((BOOLEAN)(0==1))”
The problem look like same as this post, [JETSON ORIN NANO] Boot Fail - #7 by KevinFFF
  1. Does this also happen on IGX orin platform?
  2. Can we just re-flash Bootloader(QSPI) to recovery it or need to re-flash whole OS?
BR,
david
Hi david242,
Yes, they seem the similar issue and you should be able to re-flash QSPI to recover this state.
Hi KevinFFF:
Will the issue be fixed in the next release?
If so, when will it be?
Edit:
Will the other issues, such as the power off issue caused by SMCU firmware, also be updated?
Many Thanks.
Yes, this issue should be fixed in the up-coming IGX SW1.1.
Yes, the SMCU firmware in After power off command, IGX Orin fan run in full speed - #2 will also be included.
Hi KevinFFF:
Thanks for the reply. May I know when will SW 1.1 be released?
Many Thanks.
It was targeting release in Nov. but it seems there’s some delay.
Please wait for the official announcement.
IGX SW 1.1 has been released on 2024/12/05.
