Boot slot turning to unbootable due to thermal shutdown
I have a redundant fs setup on the Jetson Orin Nano module.
It is installed on the outdoor robot and temperature can get really hot. During testing we are facing an issue that due to thermal overload, boot slot is set unbootable and it enters recovery mode at the end.
As of now, I need a serial comm to get it out of it.
How to not enter recovery mode for multiple thermal shutdowns?
Is there any way to setup a delay between reboots for thermal overload?
Hi bnbhat,
Are you using the devkit or custom board for Orin Nano?
How did you confirm this?
Could you share the full serial console log for further check?
