I had the same issue with Ubuntu 20.04 but I managed to resolve it with the help found on this forum, but now when I upgraded to 22.04 the same issue happens again.
I guess the Nvidia driver version doesn’t matter but here it is just in case: 515.65.01
Kernel: 5.15.0-46-generic
This is my grub file:
# If you change this file, run 'update-grub' afterward to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
# info -f grub -n 'Simple configuration'
GRUB_DEFAULT=
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=0
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nvidia.NVreg_RegistryDwords=EnableBrightnessControl=1 acpi_backlight=vendor amdgpu.backlight=0 acpi_osi=linux"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
I have Legion 5 with Ryzen 7, iGPU is AMD, and the dedicated GPU is Nvidia, currently, I’m on switchable graphics.
ls /sys/class/backlight
amdgpu_bl0 ideapad nvidia_0
When I use brightness keys then the brightness file in ideapad is updated and this is not reflected on the laptop.
But if I manually edit the brightness file in amdgpu_bl0 then I see the brightness change on the laptop.
I tried changing the acpi_backlight option to video, vendor and native, but neither of those worked.
So my question is how to force the OS/kernel (or whatever) to update amdgpu_bl0 instead of ideapad.
nvidia-bug-report.log.gz (316.0 KB)
