Whenever I switch from my gpu (gtx 1060) to my igpu (Intel 530), I cant boot. The loading screen is stuck with the following message:
[Failed] Failed to start NVIDIA Persistence Daemon. See ‘systemctl status nvidia-persistenced.service’ for details.
However, I can boot when I switch back to the Nvidia gpu.
Switching to my igpu does not work at all, when I logout the screen freezes and when I reboot I get stuck in a boot loop.
I’m using Kubuntu 16.10 and only my internal laptop display.
That’s the output when I switch to my igpu:
sudo prime-select intel
Info: the current GL alternatives in use are: [‘nvidia-378’, ‘nvidia-378’]
Info: the current EGL alternatives in use are: [‘nvidia-378’, ‘nvidia-378’]
Info: selecting nvidia-378-prime for the intel profile
update-alternatives: using /usr/lib/nvidia-378-prime/ld.so.conf to provide /etc/ld.so.conf.d/x86_64-linux-gnu_GL.conf (x86_64-linux-gnu_gl_conf) in manual mode
update-alternatives: using /usr/lib/nvidia-378-prime/ld.so.conf to provide /etc/ld.so.conf.d/x86_64-linux-gnu_EGL.conf (x86_64-linux-gnu_egl_conf) in manual mode
update-alternatives: using /usr/lib/nvidia-378-prime/alt_ld.so.conf to provide /etc/ld.so.conf.d/i386-linux-gnu_GL.conf (i386-linux-gnu_gl_conf) in manual mode
update-alternatives: using /usr/lib/nvidia-378-prime/alt_ld.so.conf to provide /etc/ld.so.conf.d/i386-linux-gnu_EGL.conf (i386-linux-gnu_egl_conf) in manual mode
Result of lspci -k | grep -EA2 ‘VGA|3D’
[i]00:02.0 VGA compatible controller: Intel Corporation HD Graphics 530 (rev 06)
DeviceName: Onboard IGD
Subsystem: CLEVO/KAPOK Computer HD Graphics 530
01:00.0 VGA compatible controller: NVIDIA Corporation GP106M [GeForce GTX 1060] (rev a1)
Subsystem: CLEVO/KAPOK Computer Device 6a03
Kernel driver in use: nvidia[/i]
The attached nvidia-bug-report was not created after the bug occurred, since I wasn’t able to open the console (alt-ctrl-f1), the computer didn’t respond at all.
Could you please help me?
nvidia-bug-report.log.gz (122 KB)
