Nvidia X Server Settings is disappeared from taskbar.
** Message: PRIME: Requires offloading
** Message: PRIME: is it supported? yes
So i can’t switch back to Intel.
Is there any fix coming to it?
dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualglrx'
ii nvidia-390 390.48-0ubuntu0~gpu16.04.2 amd64 NVIDIA binary driver - version 390.48
ii nvidia-390-dev 390.48-0ubuntu0~gpu16.04.2 amd64 NVIDIA binary Xorg driver development files
ii nvidia-prime 0.8.2linuxmint1 amd64 Tools to enable NVIDIA's Prime
ii nvidia-settings 396.18-0ubuntu0~gpu16.04.1 amd64 Tool for configuring the NVIDIA graphics driver
What exactly is broken, can you still use sudo prime-select query/intel/nvidia? What kind of ‘Nvidia X server settings’ are you talking of, some kind of panel applet?
You have the 390 driver installed but the 396 nvidia-settings, maybe do another upgrade to get the matching driver.
Problem is , Nvidia Settings applet disappeared. And somewhat Prime is not recognizing my Intel card and blocks switching to it. Even terminal way ( sudo prime-select intel ) is not working.
So how can i get that specific Nvidia 390.48 settings?
Looks like the 390 Version of nvidia-settings has been removed from ubuntu repositories. But this shouldn’t keep prime-select from working.Please run nvidia-bug-report.sh as root and attach the resulting .gz file to your post. Also attach /var/log/gpu-manager.log
Info: the current GL alternatives in use are: ['nvidia-390', 'nvidia-390']
Info: the current EGL alternatives in use are: ['nvidia-390', 'nvidia-390']
Info: selecting nvidia-390-prime for the intel profile
update-alternatives: /etc/ld.so.conf.d/x86_64-linux-gnu_GL.conf (x86_64-linux-gnu_gl_conf) alternatifini sağlaması için /usr/lib/nvidia-390-prime/ld.so.conf elle ayarlanmış kipte kullanılıyor
update-alternatives: /etc/ld.so.conf.d/x86_64-linux-gnu_EGL.conf (x86_64-linux-gnu_egl_conf) alternatifini sağlaması için /usr/lib/nvidia-390-prime/ld.so.conf elle ayarlanmış kipte kullanılıyor
update-alternatives: /etc/ld.so.conf.d/i386-linux-gnu_GL.conf (i386-linux-gnu_gl_conf) alternatifini sağlaması için /usr/lib/nvidia-390-prime/alt_ld.so.conf elle ayarlanmış kipte kullanılıyor
update-alternatives: /etc/ld.so.conf.d/i386-linux-gnu_EGL.conf (i386-linux-gnu_egl_conf) alternatifini sağlaması için /usr/lib/nvidia-390-prime/alt_ld.so.conf elle ayarlanmış kipte kullanılıyor
alternatifini sağlaması için : to provide alternative
elle ayarlanmış kipte kullanıyor: it is running with manually provided config
Both should be fine.
So it’s crashing if you boot to intel? Then the relevant logs would be from that state. Can you switch to VT using ctrl+alt+f1? Can you ssh in from another system?
If i select intel and reboot with that , it just stays with a blinking command prompt pointer. After a time waiting like that , fans ramps up. It is a very similar behaviour when i didn’t set acpi variable.
That’s odd, then. Did you do a bios upgrade recently that could have triggered this, or just a driver and/or kernel update? Though the driver shouldn’t be loaded while switched to intel anyway.
No , i didn’t update my bios. I just upgraded from 390.25 to 390.48. That’s all.
390.25 was bad , it had a problem with Darkest Dungeon. Hovering mouse on trinkets to see stats of them would crash the game on 390.25 but it got fixed on 390.48.
Looks like you can only ssh into your frozen box to see what’s going on, then.
Did you patch the 390.25 driver to work with kernel 4.15 or did you use another kernel? If so, maybe see if using the previous kernel works around the issue.
